Does the 120hz rectified ripple couple directly on the output of a class A amp?
For example if your rectified voltage is 20V with 200mV of ripple, and you feed that into a voltage regulator, will you see that 200mV of ripple directly on the output? I haven't had time to debug it, but in the amp I built as I increase ibias I start to get the 120hz hum at the speaker output. If this is the case, in general do you just need enormous power supply caps for class A amps? |
#2 |
What voltage regulator do you have?
Describe your power supply. If everything is in order you will not hear any hum.
lineup |
#3 |
Even if you have significant ripple at the input to the regulator? I only hear it when I use a large ibias (thus more input ripple). I just have a full wave rectifier, 45000uf cap on each rail, and a +/- 12 TO220 vreg (L78S12CV and L7912CV).
#4 |
I guess in theory I could be current clipping my regulators (I just read it has internal limiters). Would that make sense?
#5 |
It would make sense if you showed us a circuit diagram. Otherwise we are just guessing, based on a few snippets of random information you have given us.
However, a few general points can be made. Voltage regulators, when used properly, reduce ripple as well as stabilising DC. Class A is not particularly difficult with respect to hum, but single-ended is. Increasing bias might increase SE hum, as the active device has smaller impedance so the load sees a greater proportion of the supply rail ripple. |
| Line output as line input transformer? | bambadoo | Tubes / Valves | 7 | 22nd January 2008 06:44 AM |
| balance zen line stage input and output | hc167 | Pass Labs | 10 | 23rd October 2006 03:29 PM |
| Balanced line stage- input or output attenuator | nobody special | Pass Labs | 4 | 7th April 2006 01:18 PM |
| powering up old amp-120hz at output? | portlandlay | Solid State | 4 | 11th December 2005 04:36 AM |
| line output to xlr mic input | bogusblackman | Everything Else | 7 | 28th February 2004 12:32 PM |
