How to make LME49810 amp 2 ohm stable?
Old 19th November 2012, 02:34 AM   #21
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Originally Posted by tinitus View Post
ah, its standard specs ? the shown heatsink looks a bit small for that
but this 1200watt from Ground Sound I would trust more
quote
The maximum power output depends on voltage supply, heat sink and load conditions. Recommendations: Voltage supply of + / - 95V, heat sink less than 0,2 K / W and minimum load of 1,5Ω.
I visited Ground Sound products page. SMD resistors are used in their amp boards. I couldn't figure out the size of them. I guess they are 0805.
I experienced resistor thermal distortion when measured a 150 W/8R amp. The feedback resistor was 0.25 W. Abnormal high level distortion occurred for output level higher than about 80 W. Distortion cleaned up with the feedback resistor replaced by a 0.5 W resistor.
I also noticed the PA6CC and PA3CC distortion vs output charts are ruler flat from right all the way to clipping point. An interesting performance! The amp are distortion limited for all output level. It doesn't seem okay to me.
How to make LME49810 amp 2 ohm stable?Hide this!Advertise here!
2-ohm stable, but low power, amp? Serow Class D 7 15th September 2011 11:53 AM
make a kac-9102d 1 ohm stable 91h22a Car Audio 3 2nd February 2011 06:08 AM
2 ohm stable low power amp oublie Class D 18 17th December 2009 01:20 PM
Is this amp 2-ohm stable? michal Car Audio 4 1st July 2005 04:59 AM
2 ohm stable Symemetrical amp halvardf Solid State 4 14th September 2002 04:16 PM
Copyright ©1999-2017 diyAudio
