How to make LME49810 amp 2 ohm stable? - Page 2 - diyAudio
Old 14th November 2012, 07:42 PM   #11
bobodioulasso's Avatar
Simply, no. Bridging is not good for low Z.
Old 14th November 2012, 07:50 PM   #12
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
no, I know its not
but with 2x 5pair outputs, running at 40Vdc ?
it ought to last forever
better than a 1000watt driving 2ohm (?)
btw, I have a 2ohm stable 40watt with just one output pair, and it can actually drive a 2ohm speaker, no problem
Old 15th November 2012, 03:03 AM   #13
Originally Posted by tinitus View Post
you have no idea what you are doing
better forget about it
actually the above config is for 4 ohms not for 2 ohms...
using a 2kva suppy for class AB and expecting 1000watts wouldnt be a problem I believe... or we might even increase the psu to 3kva for more headroom...
Old 15th November 2012, 03:33 AM   #14
i think this one would be sufficient for driving it in 4 ohms..
1000W Mono High Power Amplifier AMP For Home Audio Or Stage Use
13 pairs of output devices...
Old 15th November 2012, 04:33 AM   #15
what should be the voltage supply if i want to bridge the 500W into 4 ohms amplifiers..
the load imp of the speaker will be about 4 ohms.
If its single module the amp can go upto 550w in 4 ohms with +/-80v supply..
now if its bridged then what should be the voltage supply?
Old 15th November 2012, 06:11 AM   #16
500w into 4R is 63volts at speaker.
Count losses, psu sagging.
About 73 volts rails will do .
Forget about bridging which brings more voltage but no more current at the speaker.
Edit:
Looking at Connex. 550 w moule specs, 78v rails 4R load is plenty
Old 15th November 2012, 06:38 AM   #17
panson_hk's Avatar
Originally Posted by bobodioulasso View Post
High voltage class AB amps are unpractical as they dissipate a lot and weigh a ton.
Better to go classD or H imho.
I agree with you. I would use high-power Class D instead a monster Class AB as this is for a sub.
Old 15th November 2012, 07:14 AM   #18
I dont understand, why the connex
1000watt amp module fully assembled and tested ? yeah, right
ok, no problem
I have 2kVA trafos, and I can barely lift just one of them
Old 15th November 2012, 08:54 AM   #19
ah, its standard specs ? the shown heatsink looks a bit small for that
but this 1200watt from Ground Sound I would trust more
quote
The maximum power output depends on voltage supply, heat sink and load conditions. Recommendations: Voltage supply of + / - 95V, heat sink less than 0,2 K / W and minimum load of 1,5Ω.
Old 15th November 2012, 09:02 AM   #20
Just meant rails voltage. Of course heatsink has to be a lot larger and even need a fan.
Anyway, at that power, current limiters are a must. I do not see any in the connex module.
2-ohm stable, but low power, amp? Serow Class D 7 15th September 2011 11:53 AM
make a kac-9102d 1 ohm stable 91h22a Car Audio 3 2nd February 2011 06:08 AM
2 ohm stable low power amp oublie Class D 18 17th December 2009 01:20 PM
Is this amp 2-ohm stable? michal Car Audio 4 1st July 2005 04:59 AM
2 ohm stable Symemetrical amp halvardf Solid State 4 14th September 2002 04:16 PM
Copyright 1999-2017 diyAudio
