Input capacitor 2.2uf Polystyrene or Mundorf Silver/oil? - diyAudio
Old 13th November 2012, 08:02 AM   #1
Default Input capacitor 2.2uf Polystyrene or Mundorf Silver/oil?
which input capacitor is best for SS? I have personally used Polystyrene and found ultra high resolution in the sound but since I never listened to Mundorf silver oil caps thought if anybody might have compared these two caps would help me in saving 200 dollars... can anybody tell me how does it compare? can polystyrene beat Mundorf silver oil?
technically speaking polystyrene should be better than any polypropelene but how is the sound compared when compared to Mundorf is a big question...
Old 13th November 2012, 09:25 AM   #2
wintermute's Avatar
Unfortunately you are in (almost) completely subjective territory here, and in reality the only person who is going to be able to decide is yourself.
The reason I said almost is because when you start getting very large capacitors (that the board was probably not designed to cope with) there is a real possibility that there could be unintended negative effects (which may be quite quantifiable).
In the end your ears and brain will tell you whether or not you have wasted your money, and for each individual this could be different.
If you have any doubts (or could spend the money more wisely on something else) I'd not fork out the cash.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 13th November 2012, 06:20 PM   #3
Only get caps from reputable manufacturers with proper science and research behind their products, like Panasonic or Rubycon, etc. Mass produced and cheap, and working as they should.
I would expect that Mundorf or other small "audiophile" companies don't not fall into this category. They simply can't afford to compete with the expertise (and R&D) of proper capacitor manufacturers.
Old 13th November 2012, 06:39 PM   #4
luvdunhill's Avatar
You really think Mundorf has their own capacitor assembly line? Ever heard the term contract manufacturing?
For Sale: Yet-Another-FirstWatt-PSU | "CSX1/2" "Buffered F6" FE
Old 13th November 2012, 06:48 PM   #5
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
To be fair, Mundorf's parent company is one of the largest capacitor manufacterers in the world.
I would pick the Mundorf Silver/Oil because I have heard them (using them in my tube amp) and they sound very good to me. They are also quite small in size, for their voltage rating.
Old 13th November 2012, 06:50 PM   #6
With the cost of these capacitors though, it'll be better just to use an amp design that doesn't require input coupling capacitors.
Old 13th November 2012, 07:30 PM   #7
moschfet's Avatar
give a big electrolytic capacitor a chance
220µF/25V at 10K inputresistor.
Regards http://xipix.de/
Old 13th November 2012, 11:58 PM   #8
lanchile's Avatar
Do not go too crazy about it and save some money! I would not use Polystyrene caps in the inputs. I always use Sonicap and they are very good. I use Mundorf audio grade caps for my power supply only!
Old 14th November 2012, 12:21 AM   #9
I doubt anybody could hear a difference between polystyrene and polypropylene caps of the same value in a blind test. The losses and distortions are so low as to be almost unmeasurable. Even with a ppm resolution bridge and various other tests I wouldn't be able to tell the two apart with any certainty. The differences between two manufacturers of the same type would almost certainly be larger than the differences between the dielectrics in general. I'd be more interested in microphonics, if they're an issue at all, and capacitance to nearby grounds and circuitry due to size differences.
I may be barking up the wrong tree, but at least I'm barking!
Old 14th November 2012, 12:24 AM   #10
Triodethom's Avatar
My question is what preamp before this amp ? Why do you think you need this cap ? Cap where used in the signal path of tubes because power supplies where expensive and thus used only one ht supply and blocked dc between stages . Point being is you may not need them at all saving 100s of dollars . No cap sounds like no cap at all. Please explain why you want in input cap .
Caps - Mundorf Silver/oil vs silver/gold/oil drjb Parts 103 13th July 2016 08:05 AM
FS : Mundorf Silver/Gold/Oil 2.2uF pinnocchio Swap Meet 11 4th November 2012 09:17 PM
Adding a Mundorf Silver/Oil Cap to Arcam FMJ P7 RCA Input? soundengine355 Solid State 2 29th March 2009 12:41 AM
Mundorf supreme silver/oil Salas Multi-Way 49 16th November 2006 08:48 AM
Mundorf Silver-in-Oil Capacitors kmtang Parts 4 23rd April 2005 02:00 PM
Copyright ©1999-2017 diyAudio
