FETZILLA - The Builders Place
Old 18th November 2012, 09:23 PM   #11
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Originally Posted by GregH2 View Post
Meanman, You will find a circuit which nearly meets your requirements here: Simple 85W amplifier However, if you wait a few weeks I will be posting a 70W quasi BJT version which I think will be the best sounding... Cheers, Greg.
I'm very curious
Old 18th November 2012, 09:26 PM   #12
GregH2 is offline GregH2  Australia
GregH2's Avatar
Originally Posted by meanman1964 View Post
I've the FetZilla a while now and was thinking myself it wouldn't be easy cause it's realy a special amp.Many whom has hear this amp were impressed.
Yes, more power is possible, but it the beautifully simple circuit topology of the lower power version which makes it sound so good I think. Everything just comes together - the device dissipations, the circuit simplicity and the actual devices themselves. More power needs more parts and/or different devices.
I think a version with a cascoded input JFET, an IRF610 VAS running at 20mA or more, and paralleled lateral outputs would do quite well. Hopefully someone will give it a go. I am trying to avoid building amplifiers with rare or specialised parts these days.
The other option is to replace the input with a small mosfet such as the ZVN2110G which also sounds pretty good. The problem is the high input capacitance, though the sonic effect of this isn't as bad as one might think.
Old 18th November 2012, 09:31 PM   #13
Bigun is offline Bigun  Canada
Bigun's Avatar
Hi Lineup,
I like this general topology, the way you draw it makes it look very simple.
Reminds me of the JLH Class AB published in 1970, [http://sound.au.com/tcaas/jlhab2.htm]which of course was all BJT.
I do like the use of Laterals in the output for simplifying the thermal stability of the bias. I suppose this is the only output device that we can use without adding some temperature compensation ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 18th November 2012, 09:35 PM   #14
GregH2's Avatar
Originally Posted by Bigun View Post
Hi Lineup,
Yes, and I can promise you the laterals sound better and probably load the VAS a lot less than undriven BJTs. Unless you want to run very high VAS currents which in turn requires a buffered or darlington VAS.
Old 18th November 2012, 09:40 PM   #15
Greg,Maybe it's better for me to give your Simple 85watt amp a go
For my own use I don't need a more powerfull FetZilla
Old 18th November 2012, 09:54 PM   #16
The FetZilla I've build is realy a special amp with nice mids good staging and detailed hights and very strong tight bass.If we need power it is only for the bass region.Is it possible to design a kind of a Fetzilla topology that goes to max 200Hz wouldn't this make things easier to design?
Old 18th November 2012, 10:39 PM   #17
Bigun's Avatar
meanman, how would you compare your FetZilla with your DX blame ?
Old 19th November 2012, 12:25 AM   #18
Jay is offline Jay  Indonesia
Banned
Quasi! And good sounding! That will be my vote for the best circuit of the year
What a teaser!
Old 19th November 2012, 05:34 AM   #19
The Fetzilla is more open more detail crispy hights and controlled bass but I also like the Blame ST.
Will get back on that after I compaired them together on the same speakers.
Old 19th November 2012, 06:51 AM   #20
lineup is offline lineup  Sweden
lineup's Avatar
Cascoded input, IRF610 VAS and Laterals parallelled at output.
Sounds as the way to go.
lineup
FETZILLA - The Builders PlaceHide this!Advertise here!
Swordfishy/ASPEN FETZILLA power amp AKSA AKSA 1213 28th April 2017 01:54 AM
Group Buy #2 - FETZILLA AKSA AKSA 252 18th April 2014 02:09 AM
Fetzilla Build Documentation Woody1911a1 AKSA 234 23rd December 2013 03:37 PM
Group Buy #3 - FETZILLA, the amp... AKSA AKSA 44 28th September 2012 07:11 PM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 09:26 AM
Copyright ©1999-2017 diyAudio
