diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Musical Fidelity A100 resistors (http://www.diyaudio.com/forums/solid-state/223123-musical-fidelity-a100-resistors.html)
yossy993 8th November 2012 11:34 AM
I bought recently A100 which is very bad condition,and am trying to repair power supply circuit. I found out R1 & R2 were faulty and their color code fadeout.
Dose anyone know resistance of R1 and R2 ? I put each 0.47ohm resistor as the same as A1. Now plus minus voltage over 41-volt against
plus minus 24-volt. Input AC100V after through transformer dropped about AC32V. I surely did mistake. Please help.
Is A100 Transformer 2ndary AC32V correct ?
Thank you
christchurch 29th November 2012 07:15 PM
0.47 ohm
Ian Finch 30th November 2012 03:40 PM
Read these pages if you haven't already. The details you want are there. The A1 & A100 are very similar.
Musical Fidelity A1
Adq 9th January 2013 11:17 AM
Originally Posted by yossy993 (http://www.diyaudio.com/forums/solid-state/223123-musical-fidelity-a100-resistors.html#post3233359)
Thank you
Hi yossy993, on my A100 the value of R1 and R2 is 0.33 ohm , the power transformers AC output is 30-0-30 without load , the DC voltage when circuit running drop at 32-0-32 ( instead of being next to 42 V) :p
Copyright 1999-2017 diyAudio
