TO-3 Removal - diyAudio
Old 6th November 2012, 10:21 PM   #1
Einric is offline Einric  United States
Einric's Avatar
Default TO-3 Removal
How do you remove TO-3's?
They are bolted through a heatsink and soldered to the pcb.
Old 6th November 2012, 10:30 PM   #2
I think you have a pretty good handle on what you need to do reading the question....
1. Desolder leads. (Prior to unbolting)
2. Unbolt
3. Clean up any heat sink goo
And you are off
Installation is reverse of above
Old 6th November 2012, 10:31 PM   #3
diyAudio Member RIP
Hi, ?, undo the bolts and desolder the pcb connections, rgds, sreten.
Old 6th November 2012, 10:46 PM   #4
Einric's Avatar
Well this is a single sided PCB.
I'm pretty sure that there is through plating on the holes so I should be able to desolder them from the bottom.
I was just wondering if there was some trick.
I have two matched triplets of 2SJ50's and two matched triplets of 2SK135's that I want to save.
They are rare and may be nice for another project down the road.
Old 6th November 2012, 10:56 PM   #5
diyAudio Member RIP
If a service engineer needed to do it a lot they would probably have
a soldering iron head that does both pins at once, allowing you to
simply lift the device out, and then clean up the board, a lot faster.
Same with removing op-amps etc, specialised soldering iron heads.
rgds, sreten.
Old 6th November 2012, 10:57 PM   #6
Einric's Avatar
I do have 2 soldering irons, LOL.
Old 7th November 2012, 03:16 AM   #7
If the board is single sided, it won't be "through-plated". Maybe a rivet or bush is fitted in some specialised gear of old. If you aren't too experienced, use solder-wick or similar fluxed braid to remove all solder first. That makes it as easy to drop the part out with just one iron as when it was first dropped in!
Ian
Old 7th November 2012, 03:57 AM   #8
Einric's Avatar
I got them out and the boards had a hollow rivet that the leads dropped through.
I just alternated between pins and they slid out under their own weight.
saa7030 removal help billbo Digital Source 12 11th August 2008 08:52 AM
Removal tools Tom7227 Car Audio 1 21st July 2007 03:02 AM
Need help of heat removal. GeDeon Pass Labs 2 10th May 2004 09:04 PM
Copyright 1999-2017 diyAudio
