Leach amp input sensitivity
Old 3rd November 2003, 11:13 AM   #1
Has is offline Has  Croatia
Default Leach amp input sensitivity
Hi
How i can change input sensitivity for my Leach from now around 2V to around 1,3V.
Old 3rd November 2003, 12:08 PM   #2
BobEllis is offline BobEllis  United States
BobEllis's Avatar
Try changing R-19 to something smaller. Might affect the sound, but if you don't like it, put the original R-19 back in and figure out how to get more drive from your preamp.
See http://users.ece.gatech.edu/~mleach/lowtim/fdbk.html for an explanaiton of the feedback scheme
Old 3rd November 2003, 12:23 PM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Is the Leach amp capable of 40 V rms out (with the PS you have got)?
The amp has gain of 21, a rather normal value. Don't have too much gain beacuse you only get more noise.
The gain is set by (R17+R18)/R19 + 1
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 61 paid.
Old 3rd November 2003, 01:14 PM   #4
mcp is offline mcp  United States
Default Changing feedback values
Changing R19 is best done with a scope and a variac or a light bulb. It takes less than a second to blow output transistors once the amp burst into hf oscillation. Cheers.
Michael Chua
Old 3rd November 2003, 10:54 PM   #5
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
if i am not mistaken, increasing the voltage gain to get better sensitivity have an impact on bandwidth, the amps were designed to have a bandwidth of 8mhz, this is fixed so that increasing the voltage gain, decreases the closed loop bandwidth...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 4th November 2003, 06:37 AM   #6
I believe you meant a gain bandwidth product of 8MHz.
Michael Chua
Old 4th November 2003, 08:14 AM   #7
TonyTecson's Avatar
hi mcp,
yes, my mistake, its actualy gain bandwith product!!!!
Leach amp input sensitivityHide this!Advertise here!
Input sensitivity on amp? suspencefull Solid State 25 3rd September 2006 07:44 PM
BJT input dv/dt sensitivity zilog Class D 0 18th January 2006 07:31 AM
BOZ input sensitivity gema Pass Labs 0 29th July 2002 10:55 AM
input sensitivity [SoZ] Phage Pass Labs 2 21st January 2002 04:07 AM
Input Sensitivity StefanJ83 Everything Else 1 20th November 2001 10:17 PM
