joule thief (draw more power from a power supply?) - Page 2 - diyAudio
Old 6th November 2012, 06:51 PM   #11
Mooly's Avatar
All the things we used to do in the name of research
Old 7th November 2012, 12:06 PM   #12
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Originally Posted by Rundmaus View Post
Yes,
it will not kill any human, but the back EMF created even by a 5V small-signal relay coil is high enough to kill LEDs, transistors or other semiconductor parts - probably also true for amplifier ICs!
Greetings,
Andreas
Mmm, audio amplifier normally has high value caps in parallel that overdampes the spike. I believe can kill a led , but I doubt can kill an audio amplifier.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Power tube maximum current draw from a power supply razorrick1293 Tubes / Valves 4 4th November 2011 10:48 PM
Orion 2150GX power draw Dr Zeus Car Audio 4 27th June 2011 02:59 AM
Advantage to constant current draw from power supply? jerluwoo Tubes / Valves 2 25th December 2010 11:00 PM
Joule Thief - LED low voltage Power supply - With pictures vr4 Everything Else 7 12th February 2009 12:49 PM
Nuuk's buffer's current draw (and power supply) dsavitsk Chip Amps 0 16th April 2005 10:04 PM
Copyright 1999-2017 diyAudio
