New Lineup IDEA - Power Follower/Output stage - Page 2 - diyAudio
Old 4th November 2012, 02:26 PM   #11
lineup is offline lineup  Sweden
lineup's Avatar
Originally Posted by Fast Eddie D View Post
Kudos. I like this implementation with the local feedback in the output stage.
Is this buffer linear enough to operate out of the global feedback loop? It does have local feedback. Because if you build it as a two stage amplifier, you will have less distortion fed back to the op amp. Do you think this is worth a try?
It is very precise with MOSFET output devices. Not much distortion.
My guess it is like THD 0.002%
So it can be used outside feedback loop. I will test to see the figures.
Another thing which Bonsai mentioned in post up here is the DC Offset on output. It can be an issue in real circuit. But I think we can find a way to balance output close to zero.
Another redical solution to DC Offset is to use output cap. This is something we never should be afraid of. Many old amplifiers performed very well usning big output caps.
lineup
Old 4th November 2012, 02:49 PM   #12
lineup's Avatar
Fast Eddie D.
Here are my testings for Power Buffer.
I put signal at buffer input. No feedback. I did test with FFT on output.
8 Ohm.
04 Vp = 01 Watt THD 0.00020%
08 Vp = 04 Watt THD 0.00042%
12 Vp = 09 Watt THD 0.00067%
16 Vp = 16 Watt THD 0.00093%
We can see the buffer performs very well. Better than 0.001% is very good. So in real circuit the distortion will be very low. My guess is better than THD 0.005%. This is better than most power buffers I know about.
lineup
Old 4th November 2012, 03:15 PM   #13
Good. You do realise the practical advantages to a two stage power amp, right? It can reduce speaker interaction with the amplifier. There are discussions of this in another thread here.
When back emf is fed back into a unity gain feedback network, it is not amplified. When it is fed all of the way back to the input voltage gain stage, it is amplified!
Old 4th November 2012, 03:20 PM   #14
lineup's Avatar
Yes. I know about this. The speaker has a coil and can transmit pulses into global feedback loop.
This is where a circuit like my power buffer can do a duty.
One voltage amplifier with local FB. And one buffer to follow. And no back emf to the voltage amplifier.
lineup
Old 4th November 2012, 04:04 PM   #15
That's it. My old Nakamicha TA4A reciever works that way. It is very well behaved and very powerful in an "old school" way. It uses a traditional diamond buffer with current sources. It's my favorite solid state amp. It can drive any single pair of speakers "6 ohms nominal" or higher quite well.
Old 5th November 2012, 09:57 AM   #16
lineup's Avatar
Nakamichi has done a lot of good things. I have own a Nachamichi taperecorder. It was the best
lineup
Old 5th November 2012, 10:10 AM   #17
lineup's Avatar
Here is the next part in development of this circuit.
I have added 'real' current sources.
I have added 2 compensation caps. This makes the circuit have good stability. I think it slows down the MOSFETs.
Now is only half the distortion att full output (30 Watt into 8 Ohm).
The input impedance is >11k. THis makes the buffer an easy lood for the frontend.
I now use OPA604 for voltage amp. It has max +/-25 VDC supply.
And so it can put out +/-22 Vpeak.
The diagram shows circuit at full +/-22 Vpeak output.
THD is 0.00067% at 30.25 Watt output.
Where OPA604 contributes 0.00028% and the buffer 0.00039%
These are good figures. It points to we can build a very good amplifier which is not too complicated.
THe MOSFETs run in 217mA idle.
lineup
Old 5th November 2012, 11:51 AM   #18
Workhorse's Avatar
Nice idea Lineup, one can construct a pure class-A preamp section also using your topology, as it nicely fits in some of the places of interest.
Old 5th November 2012, 12:03 PM   #19
lineup's Avatar
Yes.
With a discrete Class A preamp we can put out more Watt.
Chip opamps are restricted to lower voltage. (Max 30 Watt)
I have now adjusted the needed capacitance across GATE-DRAIN for MOSFETs.
One cap 1.5nF across seems to be pefect for AC values.
The input impedance is set by those two resistors to ground.
lineup
Old 5th November 2012, 12:15 PM   #20
lineup's Avatar
Here is the AC Analysis with those 2 caps across MOSFETs.
And the current working circuit.
1. OPA604 as voltage amplifier +/-22Vpeak.
2. The Power buffer
Total THD 0.00067% for both parts.
lineup
four transistor emitter follower (diamond buffer) as power output stage? capslock Solid State 114 22nd February 2015 10:51 AM
mosfet source follower output stage. Printer2 Tubes / Valves 21 18th January 2013 04:43 AM
LINEUP Input-VAS, idea lineup Solid State 57 14th March 2011 11:33 PM
Do we always need an emitter follower to drive a LATFET output stage??? Leolabs Solid State 37 9th January 2011 04:16 PM
Cathode follower Class A output stage? Circlotron Tubes / Valves 14 15th May 2003 11:11 PM
Copyright 1999-2017 diyAudio
