New Lineup IDEA - Power Follower/Output stage
Old 14th November 2012, 11:59 AM   #121
jkuetemann is offline jkuetemann  Canada
jkuetemann's Avatar
Originally Posted by lineup View Post
Great jkuetemann.
If you go back to the beginning of this thread,
you see I use simple pair of IRFP240/IRF9240 for output.
The numbers were very good.
This circuit now shown to work good with following outputs
- pure MOSFET pair
- Lazy Cat BIGBT
- Triple darlington BJT
I must say it is a nice Power Buffer.
EVerything points this way.
Next I will go back to the MOSFET output, once again
The somewhat higher input impedance of the MOSFET Gates
is good for the results.
There is also higher voltage across the input transistors.
Like 4+4 Volt.
I spent some time playing with the lower CCS currents to get the circuit into a balanced condition (BTW, the input pair balance is very touchy and important for performance) and got some nice numbers. I'm wondering about some kind of current mirror with one leg reflected to the opposing rail for the front end to keep it well balanced. The diamond pair seems to be more important with respect to output offset and as such I think is best left adjustable. Currents were ~100mA through the BIGBT BJTs and 50mA through the MOSFET driver.
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 14th November 2012, 12:03 PM   #122
lineup is offline lineup  Sweden
lineup's Avatar
This is a Combined Voltage Amp Opamp
and
The Power Buffer.
The OPamp has got voltage feedback and TMC error correction.
It is rather precise.
The LU Power Buffer is one version with Triple EF.
The buffer and voltage amplifier work separately.
There is no global feedback.
These are the simulated THD figures
Combined VoltageAmpSC2240_1c PowerBuffer_6p
Power Supply is +/-42 Volts
THD 1kHz
04 Vp, 01 Watt THD 0.00016%
08 Vp, 04 Watt THD 0.00024%
12 Vp, 09 Watt THD 0.00034%
16 Vp, 16 Watt THD 0.00044%
20 Vp, 25 Watt THD 0.00054%
24 Vp, 36 Watt THD 0.00067%
28 Vp, 49 Watt THD 0.00080%
32 Vp, 64 Watt THD 0.00095%
36 Vp, 81 Watt THD 0.00115%
40 Vp,100 Watt THD 0.89761%
THD 20kHz
04 Vp, 01 Watt THD 0.00227%
08 Vp, 04 Watt THD 0.00219%
12 Vp, 09 Watt THD 0.00223%
16 Vp, 16 Watt THD 0.00212%
20 Vp, 25 Watt THD 0.00213%
24 Vp, 36 Watt THD 0.00260%
28 Vp, 49 Watt THD 0.00381%
32 Vp, 64 Watt THD 0.00593%
36 Vp, 81 Watt THD 0.00919%
Those a good numbers, but no doubt can be made better with other versions of the LU Power Buffer.
We now call this buffer: LU Power Buffer
where LU stands for Lineup
lineup
Old 14th November 2012, 12:17 PM   #123
lineup's Avatar
The mirror current source is a good idea.
The DC Offset should be solved some way.
If people see an Output cap,
they shake their head and go elssewhere.
Myself is not at all afraid of using Output capacitor. Say 10.000uF
When we use NPN + PNP MOSFET output pair
we can get offset like several 0.1 Volt.
Because one MOSFET can have 4.3 and another 4.5 VGS.
One idea is the let the frontend 10+10 Ohm be one trimpotentiometer.
A precision trimpotentiometer of 20 Ohm
and take the input through the wiper somewhere in middle.
This calls for having maybe 0.3+0.3 Volt across the input trimpot.
If this voltage is too low, then the adjustment may not be enough.
lineup
Old 14th November 2012, 12:25 PM   #124
homemodder is offline homemodder  Portugal
Those figures are dissapointing given the low THD from the buffer. Now try a straight forward Blameless amp and use TMC with it. It will result in much better figures.
Old 14th November 2012, 12:33 PM   #125
MiiB is offline MiiB  Denmark
What about a Lateral MOSFET output... Could be be good also...
Old 14th November 2012, 01:36 PM   #126
Jay is offline Jay  Indonesia
Banned
Yes, I think the bottleneck is the driving circuit. About the buffer itself, it is a buffer, with normally low distortion. Now the question is, is the extra low distortion worth the extra complex buffer circuit. I mean, many other simpler buffers are low distortion, even if they are not super low.
Old 14th November 2012, 01:51 PM   #127
lineup's Avatar
Try to setup a diamond normal power buffer,
and you see what distortion figures you get.
That is what I call disappointing
I agree with homemodder regarding a Blameless with negative feedback and TMC.
But then you have global negative feedback over your ears.
This buffer approach try to get away from GNFB.
And so, like Struth understands we get 2 distinct parts with only local feedback.
lineup
Old 14th November 2012, 01:55 PM   #128
lineup's Avatar
Good idea MiiB.
I will try this when I get time.
This might be the best approach. We all know what Laterals can do.
I have the SPICE models of 2SK1058 and 2S162
lineup
Old 14th November 2012, 02:11 PM   #129
Banned
Cool, we might put some circuits from the discrete opamp open design thread to drive the buffer. I myself have some opamp projects waiting for this kind of job.
Old 14th November 2012, 04:01 PM   #130
Whats wrong with GNFB ??
How can you define as being local feedback. Here you have two GNFB loops, Im not sure which is worse.
New Lineup IDEA - Power Follower/Output stageHide this!Advertise here!
four transistor emitter follower (diamond buffer) as power output stage? capslock Solid State 114 22nd February 2015 11:51 AM
mosfet source follower output stage. Printer2 Tubes / Valves 21 18th January 2013 05:43 AM
LINEUP Input-VAS, idea lineup Solid State 57 15th March 2011 12:33 AM
Do we always need an emitter follower to drive a LATFET output stage??? Leolabs Solid State 37 9th January 2011 05:16 PM
Cathode follower Class A output stage? Circlotron Tubes / Valves 14 16th May 2003 12:11 AM
Copyright ©1999-2017 diyAudio
