help with Luxman l-200 - diyAudio
Old 1st November 2012, 12:49 AM   #1
Default help with Luxman l-200
Greetings!
I recently aquired a luxman l-200 and what i need help with is how to change the bulb to a l.e.d and what parts i need to modifiy with the associated circuit.
Thanks in advance!
Old 7th November 2012, 06:48 AM   #2
bump! i want to fix this soon so i can enjoy this musical beast!
Old 7th November 2012, 06:52 PM   #3
RS232 is offline RS232  United Kingdom
Well if the supply for the bulb is AC you going to need:
1 diode (any 1N400*)
1 resistor to set LED current
1 diode of your choice
If it is DC you don't need the diode
Ric
Old 2nd February 2013, 04:40 AM   #4
vynuhl.addict's Avatar
The Luxman runs the lamps from 20v dc rails, negative supply if I'm correct. Even if it were ac you could still use the led since regardless of its orientation it will conduct on either the positive or negative half of the ac pulse just like any diode. You however will need to observe the voltage from the rail and use a current limiting resistor. I just refurbished an l235 but changed to amp circuit to incorporate nested feedback and a better power supply. It's a good little amp, but miles away from my Current Feedback open loop design.
Colin
Old 2nd February 2013, 06:03 AM   #5
Art M is offline Art M  United States
Originally Posted by vynuhl.addict View Post
The Luxman runs the lamps from 20v dc rails, negative supply if I'm correct. Even if it were ac you could still use the led since regardless of its orientation it will conduct on either the positive or negative half of the ac pulse just like any diode.Colin
If you reverse Bias an LED, failure is eminent. The Avago HLMP series is
rated for 5V@100uA (some brands rated at 10uA) maximum reverse voltage. Reverse it at 20V and you will probably will soon have a Blown diode.
Old 2nd February 2013, 08:24 AM   #6
That's why you implement a dropper resistor, this will knock down the voltage, all you need to do is measure the rails and adjust accordingly for a decent bias, 4ma is sufficient or lower if you want a duller brightness. It's crude but it will work, however yes on the reliability factor dc will function better. A simple low power 1n4148 is sufficient for such low power.
My Dead Arcam 200 AVR project/helpHi all 0/ Basically I have an old Arcam 200 AVR tha Fivetide Solid State 4 5th July 2011 07:18 PM
Luxman LV105 musicfan Solid State 5 23rd January 2011 11:44 AM
Luxman joelfl Solid State 3 18th August 2010 10:05 AM
Difference between Hertz HS-200 and HX-200 FaZ72 Multi-Way 2 8th April 2004 01:34 PM
Aura Ca-200 / Pa-200 cdl Solid State 8 7th October 2003 12:13 AM
Copyright 1999-2017 diyAudio
