#81 |
somebody's doin' it ......
#82 |
diyAudio Retiree
DO NOT RUN K389 AND J109 AT 32 VOLTS.
There also needs to be gate resitors on the mosfets and preferably the jfets as well I would cascode or series zener drop the drain voltages for the JFETs. I wonder if an amp from this schematic was actually built...... |
#83 | |
diyAudio Retiree
#84 |
#85 |
diyAudio Retiree
The J109s are good for 30 Volts....... There are reasons for a cascode circuit besides just the drain to source voltage being too high.
#86 | |
Banned
JFets get noisy at high supply voltage because of leakeage, though not destructed. See the datasheet of f.a 2N5912 at www.vishay.com and Horowitz. I learned it the hard way. Some form of cascoding will prevent this from happening. |
#87 |
http://www.ne.jp/asahi/evo/amp/device/2sj109.pdf
Oops.......See what you mean.......Strange they call them complementary? I like super simple so don't do cascodes. .........mike |
#88 |
diyAudio Retiree
Give that man a gold star. I was also considering power dissipation which is about 200 mW for these devices.
#89 |
The circuit should work, just as it is. Gate resistors are most probably optional on this design. Why? I don't know why you like gate resistors of jfets. All it does, in this case, is to make the input more noisy.
#90 |
Simple is good, but not the best. This amp (post 81) will have pretty high distortion, driving gate-source capacitance of the Mosfets.
| Discrete Dual Differential DAC? | dantwomey | Digital Source | 18 | 5th March 2011 07:24 AM |
| single-ended to differential? | gentlevoice | Digital Line Level | 16 | 17th December 2008 07:18 AM |
| Single Differential Non-feedback | lumanauw | Solid State | 3 | 5th September 2004 03:29 AM |
| Differential to single ended... | Bas Horneman | Tubes / Valves | 21 | 2nd April 2003 03:05 PM |
| Page generated in 0.10212 seconds (76.92% PHP - 23.08% MySQL) with 11 queries |
