#71 | |
Mr Curl, Cascoding could work good, but would'nt be easier to use other output devices? (better matched ones) Could you explain me why it has low gain? I thought that dif pairs had a very high gain. Are dual differentials different? So, can hitsware's schematic be used as if, without feedback? |
#72 | |
diyAudio Senior Member
Frank |
#73 | |
#74 | |
#75 |
As an output stage ..... NOT a line amp .....
#76 |
diyAudio Retiree
Change the resistor connecting the sources of N pair and P pair of JFETs to three delta connected resistors with the bottom resistor between the sources of the P JFET pair. Adjusting the value of this resistor will change the degeneration and gain for that half of the circuit to compensate for the N channel MOSFET's greater transconductance than the P channel MOSFET. The parallel combination of the other two resistors will set the bias current of the JFETs independently of the value of degeneration resistor for the P pair of JFETs. You also need to cascode the JFETs for supply voltage above about +/- 20 volts. R1 and R3 will set the bias for the the front end and output stage and will be something different than value shown on the schematic below.
#77 |
Actually, this makes a pretty lousy power amp, BECAUSE there is no loop gain with a low Z load. Makes a darn good line amp, however.
I even made the Grateful Dead line driver to drive the final mix from the mixing board to the stage with a similar configuration. All else being equal, fets are better than bipolars, but sometimes bipolars are useful in this circuit. |
#78 |
diyAudio Retiree
Well, maybe not no loop gain. The Hitachi K1058/J162 pair biased at half an amp would give an output stage gain of about 5 for 4 ohms I believe. With two pair of output devices and some fairly low value drain resistors for the JFET front end to drive the MOSFET Gate to source capacitance, I bet you could get 16 or 20 dB of negative feedback. This wouldn't be a great measuring amp but might not sound too bad. I have the parts around...... maybe I will simulate it and build it if the numbers look reasonable.
#79 | |
BUT beware (maybe a sim would catch it) of sudden 'mode shifts' for lack of a better term. Since the gain of the output stage does vary so does the feedback (if used). ALSO I think some sort of "shootthrough" (too much conduction from rail to rail through the outputs) sometimes occurs........mike |
#80 |
Fred's biasing has problems. Not in concept, but in execution. The resistor values are too large, and the differential gain is asymmetrical
| Discrete Dual Differential DAC? | dantwomey | Digital Source | 18 | 5th March 2011 07:24 AM |
| single-ended to differential? | gentlevoice | Digital Line Level | 16 | 17th December 2008 07:18 AM |
| Single Differential Non-feedback | lumanauw | Solid State | 3 | 5th September 2004 03:29 AM |
| Differential to single ended... | Bas Horneman | Tubes / Valves | 21 | 2nd April 2003 03:05 PM |
| Page generated in 0.13445 seconds (78.15% PHP - 21.85% MySQL) with 11 queries |
