#61 |
You are close, hitsware. This design concept is about 30 years old, as it was first used in the JC-2. Now, how can we improve it?
#62 |
by adding current sources?
#63 | |
#64 |
Mr.Curl,
What if we replace the resistors on the tails of the differential with adjustable current sources, we would be then able to adjust bias and dc offset at the same time. My question , how the bias stability of such a circuit would be? Regards, Jam |
#65 |
First, think about removing ALL the current sources and just using 1 resistor between the source pairs on the input. Second, this is actually a very stable design, because it has almost no gain, but 1/2A Hitachi devices can be problematic, because they are not well matched in this situation. The P channel looks like a triode, but the N channel looks like a pentode. Too much 2'nd harmonic. How do we fix this?
#66 |
Cascode the output pair?
#67 |
Yep, makes a world of difference, in this case. This is essentially the 2'nd stage for my Vendetta Research phono preamp.
#68 | |
diyAudio Senior Member
Oops... I just see you had a reply already. Cheers,
Frank |
#69 |
Mr. Curl,
If you were to update the JC-3, would this be the topology you would use? It would be fairly simple to add a Vbe multiplier and outputs to the circuit. If this is is correct would you choose bipolars (with drivers) or mosfets for the outputs, and would you still use the inverting configuration? Regards, Jam |
#70 |
Frank,
Trolling the solid state section again? ....................... You will soon be joining us. Regards, Jam |
| Discrete Dual Differential DAC? | dantwomey | Digital Source | 18 | 5th March 2011 07:24 AM |
| single-ended to differential? | gentlevoice | Digital Line Level | 16 | 17th December 2008 07:18 AM |
| Single Differential Non-feedback | lumanauw | Solid State | 3 | 5th September 2004 03:29 AM |
| Differential to single ended... | Bas Horneman | Tubes / Valves | 21 | 2nd April 2003 03:05 PM |
| Page generated in 0.10295 seconds (82.13% PHP - 17.87% MySQL) with 11 queries |
