#51 | |
yes, you're completely right about the Doug Self stage with compensation capacitor as it gives local feedback to the VAS stage. I'd be a little more precise about this. If we'd use an uncompensated or open loop VAS stage we can see, that a typical bipolar output stage will load the VAS stage witch results in heavy high order distortion of the output stage. I think in this point of view tubes and bipolar are quite different. Tubes in class AB will have lower distortion levels and lower high order distortion without any applied feedback. To my opinon and experiance an amp with low inherent (feedbackless or open loop) distortion sounds better with applied feedback. One possibility to archieve this is to use an output tripplet or a MOSFET output stage. |
#52 |
> I have another "dumb" question. ...design from Randy G Slone book, about the "Optimum Power Amp". ...when I make experiment of it, this design just doesn't work. Up until now I cannot figure what is the voltage in the base of Q11 and Q12 (first VAS transistor).
I think this was discussed before, and the consensus is that it will not work as shown. As your "dumb" (not dumb!) analysis shows, the current in the second stage is not clearly defined. As Tube Dude says, to "work" it has to be something like 2Vbe. But circuits do what you make them do, not what you think they will do. In this case there is nothing that "makes" the second stage current any particular value. This goes back to Nelson's comment about how nice it is to have one side setting currents throughout the amp: "the bias stability that such arrangements provide." You can do both sides, but there are ways to go wrong that you may not notice until you smoke a boardful of transistors. Old-hands like Pass and Curl are either smart enough or smoke-experienced enough to see these on paper, but I can still do equally dumb things despite years of smoking parts. > how come the author have measurement figures, if the amp doesn't work? I suspect the wrong diagram got printed, or the publisher's artist re-drew the author's sketch wrong. Actually: if the input quad is perfectly matched, the second stage can only draw a "very small" base current. With luck, the stage may wind up somewhere between cut-off and smoking, and actually amplify. It is not impossible that it would work. But it is hypersensitive to part parameters and generally won't work except by luck. > power amp from motorola. Why is the collector pin of Q2 and Q4 doesn't tied up to +/-VCC with it's own resistor? Returning the other side of the diff-amp to the next stage emitter gives some of the benefit of a current mirror without some of the problems. To my eye it is "ugly", but often useful. |
#53 | |
#54 |
> What keeps on surprising me is how tube and transistor problems are similar....
They are identical. Just a different balance of problems. BJT has a "junction" that current won't cross without a certain energy, and the amount of current can be calculated. FETs have a bulk resistance that can be "squeezed" by an external field, but the edge of the squeezed area is a junction. Thermionic vacuum tubes have a little of both. The cathode surface is a junction, just not a solid-state junction because one side isn't solid. But when you get down on the atomic level and look how electrons come off the cathode, you have to use the exact same physics as transistor theory. However, most of the energy applied to this junction is "heater", not Signal. Then the electrons pass through a "bulk" which is squeezed and stiffled by electric field. Philosophically, "all devices are the same". Yes, practical devices differ enough to hide the underlying unity of all electronics. Differences: * atomic-size junction or bulk effect * parasitics The practical vacuum tube is far from perfect. Cathodes hang onto electrons very hard. Somehow the cathode matter must be fluid enough to loosen electrons while solid enough to hold a shape. In operation, a monatomic layer of the surface is above melting-point while the rest of the cathode is solid. Very tricky (and poorly understood) doping is needed for great results. Then the bulk of the tube would control poorly if designed to classic "ideal cylindrical triode" geometry, real tubes use gimicky geometry to improve gain in the normal operating range. The theory books talk about 3/2-Law: you won't catch a practical triode amplifier doing any such thing. The modern (since 1965) BJT is nearly "ideal", in the sense that the theory is clear (and simple) and practical devices follow theory extremely closely. Also the atomic-sized junction with minimal bulk effect gives the absolute best transconductance of any device. (Though it is worth noting that if we had very clean Germanium, Gm would be twice that of Silicon.) A significant drawback is that all BJT devices require a significant and not clearly defined input current. The FET is a bulk device and all about geometry and clever device design. Within the range that the device is intended for, we can use simple theory for small signals, but the large signal parameters are all empirical. And the bulk geometry means the Gm tends to be lower than a BJT (though oddly this is untrue at super-low currents). The bulk geometry also means that FETs have significant capacitances and thus can draw large input currents in AC amplifiers, and for large FETs sometimes more current than a BJT even inside the audio band. You can treat tubes and FETs as BJTs that buffer (more or less) their inputs but have big variable resistors hanging on them. A BJT-nut will argue: take the gain without the losses, use BJT with precision fixed resistors. BJTs do have some bulk effects but we can cascode them away. On the other hand, if you keep adding things to fix the big errors, you end up with a growing pile of "small" errors that can get out of hand. There are a lot of many-BJT plans that are more clever than smart. This even infects tube-heads. It's not just the device. It's not just the geometry. It's not just the detailing. Everything has to play together nice. If a certain device or geometry is forced upon you (personal preference, price, existing board), you can probably detail it to a very high standard (higher than commonly found in real life). If you have a clean-sheet, it is hard to screw-up a simple tube amplifier. At a higher standard of precision, a reasonably simple and easily understood BJT design can work extrememly well (and a lot cooler than tubes). When your specs seem to suggest very complicated BJT designs, you may find that an FET design will do the job without as many "small side effects", because they are a nice compromise between the fairly low gain and precision of tubes and the hyper-high and hard-to-control gain of BJT. But when the "spec" is the musical ear, some imprecision is ignored and other faults are pinpointed. The ear is a flawed but very clever thing. We can stand in a field of chirping crickets and hear the toe-step of the tiger that is about to eat us (if our ancestors did not hear this well, we would not be here). The ear makes 10% distortion and is unflat 40+dB, but can pick-out a tone 20dB below the general noise level. The measurements that are easy are often not that important. We are nearing the point of machines as clever as the ear, but we are not using them in the same clever way as the ear. |
#55 | |
http://www.diyaudio.com/forums/showt...526#post195526. I wonder whether these current limiters in the VAS cascode stage (small print, but it seems to be Q14 and Q17 with 33Ω resistors) have something to do with the undefined bias point. At least the VAS current will be limited to approximately 20mA. If so, could that mean that Slone knew it was undefined and used this as a way to 'define' it? Not very sophisticated. Steven |
#56 | |
I've got two questions:
1. Did anyone build a version to see what would happen? 2. Did anyone ask Sloan to see what he had to say (" there is a diagram error" or "it really does work as long as you maintain the global feedback loop" or ... etc.) mlloyd1 Quote:
#57 | ||
One of the reasons our ear/brain system isn't quite the highly accurate detection system that some tend to portray it is because nature has wired us to OVERdetect. In other words, we're more prone to perceive a toe-step when there is none than to not perceive one when there is. This unfortunately makes it rather trivially easy to cause people to perceive differences in audio even when there are none. Quote:
Anyway, yeah, the ear/brain system is pretty amazing. But I think in the world of audiophilia, it often gets oversold and there's a tendency to ignore its very real limitations. se |
#58 |
On one hand, that's a good point. It is certainly safer to flinch at a hundred non-tigers than to not-hear just one actual tiger. If the tigers or wolves or fruit-tree branches don't get you, your fellow man is probably sneaking up behind you with a rock. Through most of mankind's history, life has been dangerous and some of those dangers can be heard coming. OVER-detect! On the other hand, this one simple thought could tear-away the cherished foundations of both the "I know what I hear" and the "measurements don't lie" schools of hi-fi philosophy. |
#59 |
diyAudio Moderator Emeritus
Yes, actually I have made it. The output is just big voltage plain DC, which is not affected at all with music. First I got confused with it. But when I replace the current mirrors with resistor with calculated value, it works. But the sound is not very good.
Is there anyway to determine voltage between two collectors (like between collector of differential with collector from current mirror? |
#60 |
you don't need no followers.
sort of a REAL class AB |
| Discrete Dual Differential DAC? | dantwomey | Digital Source | 18 | 5th March 2011 07:24 AM |
| single-ended to differential? | gentlevoice | Digital Line Level | 16 | 17th December 2008 07:18 AM |
| Single Differential Non-feedback | lumanauw | Solid State | 3 | 5th September 2004 03:29 AM |
| Differential to single ended... | Bas Horneman | Tubes / Valves | 21 | 2nd April 2003 03:05 PM |
| Page generated in 0.28846 seconds (47.22% PHP - 52.78% MySQL) with 11 queries |
