#301 | |
#302 |
Frank,
How can a cascoded JFET have higher gain then a non cascoded JFET? Or am I missing something...
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears" Michael 29th January 2010 |
#303 |
Hi, lumanaw...
You asked for AD 817 version for power amp application. I've built that and tested succesfully. It based on differential folded cascode with local feedback. It has about 100 W (8ohm). The result make me happy. If you interest you may contact me.. cheeers, Lukio |
#304 |
Banned
Cascode increases gain????????????? Really????
You need a remedial course, proctored by someone as mean as me. [joke] Jocko |
#305 |
Folks, this is getting you nowhere. Speculation as to how circuits work is not that same as understanding how circuits work.
First, what point is there to go to extremes to reduce the noise of the power amp? It is the last chain in the link and the vast bulk of the noise in your audio system will come from the preamp and earlier sources. Second, using a very large, expensive, fet on the input is great for MC inputs, but the inherently high non-linear capacitance in the large area input fets will give you more high frequency harmonic distortion than a more optimum geormetry like the 2SK389. Noise difference? Almost unmeasurable in a power amp design. Cascoding would reduce the distortion, but not remove it completely. Paralleling FET's is what I do for MC inputs, but it only makes the situation worse for distortion with a power amp, or even a line preamp. Think it through, look it up on the internet, or give thought of what audio designers have already stated on this thread and others. |
#306 |
diyAudio Retiree
"First, what point is there to go to extremes to reduce the noise of the power amp? It is the last chain in the link and the vast bulk of the noise in your audio system will come from the preamp and earlier sources."
This from the guy who lectured me on the noise contributions of gate resistors in line level circuits? Actually I agree, people tend focus on parameters that are relatively unimportant at the expense of those that are very important in a particular design. Unfortunately, knowing which is which comes with a lot of experience. That is why its nice to have Mr. Curl around for the insight picked up in a long and successful career as audio designer. Thanks John. |
#307 | ||
diyAudio Senior Member
A cascode with a triode was what was meant. Quote:
Frank |
#308 |
Frank,
I guess you just got spanked.......................... Regards, Jam P.S. This message has been brought to you by the SOLID STATE LOVERS SOCIETY |
#309 |
Folks, I hope we can still keep this thread going. I am not trying to stop anyone from asking questions or giving new input. However, if an experienced audio designer warns you about something, and this is not contradicted by another experienced audio designer, then, usually, the warning is valid and useful.
#310 |
Hi every body...
Here is the schematic of my folded cascode with local feedback.. The specifications are : Bandwidth – 3 db = 3 Hz -750 kHz Bandwidth – 3 db / filter = 300 kHz THD+N = 0.003 % (3-32 kHz) Slew Rate = 170 V/us Rise time step response = 1.3 us Settling time (0.01%) = 5 us Step response = Perfect w/o overshoot and ringing PSRR = +-- 70 dB (10-10 kHz) Equivalent input noise = 4.3 uV/sqrt Hz Power = 96 Watt 8 ohm 160 Watt 4 ohm Gain = 27 X ( 28 dB) S/N ratio = >100 dB Input sensitivity = 1 V Input impedance = +- 100 kOhm Output impedance = 0.15 ohm Max.output current = 4 A Supply voltage = + - 40 Volt unregulated DC offset = Max. -35 mV (Adjustable) |
| Discrete Dual Differential DAC? | dantwomey | Digital Source | 18 | 5th March 2011 07:24 AM |
| single-ended to differential? | gentlevoice | Digital Line Level | 16 | 17th December 2008 07:18 AM |
| Single Differential Non-feedback | lumanauw | Solid State | 3 | 5th September 2004 03:29 AM |
| Differential to single ended... | Bas Horneman | Tubes / Valves | 21 | 2nd April 2003 03:05 PM |
| Page generated in 0.11411 seconds (82.93% PHP - 17.07% MySQL) with 11 queries |
