#191 |
diyAudio Senior Member
Seems to me some people have difficulty in differentiating DC from AC behaviour... Back to the kindergarten and Thevenin for some of us I reckon?? Please, people, do grow up and leave your inflated egos behind... Cheers,
Frank |
#192 |
Fred,
Not long back, when Steve so exasperated me with his behavior, at his suggestion I hit the 'ignore' button. Now I only look at his comments when I'm feeling benign, composed and amused. Works for me! Hitsware, the problem with feedback is exactly as Frank explains it; thanks Frank, you covered the gaps. Here's another view, based on the order of events: input signal enters the amp, is magnified to the output (with errors), fed back to the feedback node and found to differ from the input. The error thus identified (by a diff pair with SS, with a tube it's usually cathode injection), creates an error signal which is despatched to the amp to CORRECT the output. Notice the sequence of events. The signal takes time to pass through the amplifier, called group delay, and the correction is made AFTER the event since it's taken from the output and fed back to the input. Now, in practice this is quick, particularly if fast devices (with high Ft) are used. So, a tiny error will soon be picked up, and corrected BEFORE it gets big. However, this creates overshoot, rather like a governor on a stationary diesel engine, which also reacts after the event, or temperature control of the human body, or respiration rate, triggered by carbon dioxide levels in the blood. All feedback systems, absolutely by definition, will involve this delay, sometimes called hysteresis, which leads to tiny overshoot. As it happens, by Fourier analysis, it can be shown that sharp blips in audio waveforms are made up of higher harmonics. And the problem is that even the initial overshoot will cause the feedback loop to react further, trying to correct the overshoot which results of the mechanism. In turn, this creates a cascading series of tiny overshoots, which spawn other overshoots, and so on. It is this unhappy chain of events which leads to the condemnation of global negative feedback, and like most folklore, there is some truth in it. It would seem intuitive that if we knew the error the amp would introduce in advance of processing the signal, we could make alterations to our amplifying devices so that it came out just right!! In truth, we do this to a minor degree by ensuring that each gain block is as linear as possible to begin with. This minimizes the correction necessary using global feedback, but a moments thought tells us that to achieve this we will need to modify the transfer function of our active devices to make them more linear. And guess what! To do this we reduce the gain of our devices on the spot (locally), but this actually reduces the feedback factor we can apply globally!! SNOOKERED!! You really are damned if you do, and damned if you don't. IOW, amplifier design is just life - these sorts of dilemmas are a part of life itself. The classic expression of this, in macabre but entirely logical terms, is 'The operation was a success, but the patient died'. One valid, real-world approach, in my opinion, is to have extremely fast devices and very short, non-inductive feedback and signal paths which minimize group delay and thus bring down overshoot and distortion to vanishingly low levels. We should also use very fast topologies, where possible, and make the slowest part of the amplifier the gain block, so as to control phase shift to avoid oscillation. Since the ear is preternaturally sensitive to high order harmonics, particularly odds, we have to design amplifiers which bring the H5 and beyond harmonics below the noise floor, so that any sonic impact of this unfortunate but necessary topology is subliminal rather than directly audible. Even so, no amplifier is perfect, and the discussion of sonic color added by the SET brigade brings up a whole new can of worms. I'd recommend reading Fred Nachbaur's website here: http://dogstar.dantimax.dk/tubestuf/miniblok.htm for a full and intelligent discussion of the SET, which incidentally I like very much. You ask about the AKSA. Yes, it is a single differential input pair, using highly matched transistors, very carefully chosen, and VERY carefully laid out. Cheers, Hugh |
#193 |
Hugh,
Thanks for the link. Could we say (getting back to single vs dual differential) that perhaps the single differential has a little of the euphoric qualities of the SET while the dual doesn't ? Or does the ' differentialness ' destroy that as compared to say a single jfet or bipolar xsistor as a front end. ( I know there is some differance between the 2 (fet vs bipolar) ......... Thanks again ...... mike |
#194 | |
This reminds me of the only possible flaw I made when designing my OTL amps...I should have made the feedback path shorter by building along the width of the chassis not the length. Thank you for reminding me,
Frank |
#195 |
From the peanut gallery, I certainly value John Curl's presence at a public forum; at the same time, I also value Steve Eddy's opinions. My wish is that they would give each at least another chance. Seems like they are both close to, if not on the mark. Of course, everyone has his or her quarks. Just don't let the other bother you. Seems like the same goal is in mind.
So, metaphorically, I'm for dual differential (more local feedback, less global feedback). JF |
#196 |
>So yeah, I'm for dual differential.
Why ? |
#197 |
diyAudio Moderator Emeritus
Maybe the that Japanese design is trying to search the limit of minimum power amp stages. But I think the best 2 stage power amp is Aleph. The 2 stage power amp with only 1 differential. I've tried to figure 2 stage power amp, and never got better idea than Aleph. Good sound, good stability (although very hot).
Reading the previous post, I think I began to understand what Mr.Pass said about "Anchoring" the whole amp with CCS. Dual differential cannot do that, the standing current will vary as the transistor getting hotter or more cold (bias in VBE to temp). If stability of standing current is important to output signal for an audio amp, then single differential with CCS is the best. Although it is the "OLD DESIGN" like some refer to Doug Self design. But IF single differetial with CCS is better from dual differential, why is there so many famous brand (like Crest) is using dual differential up until now? |
#198 |
Don't want to go off topic, but one: I was writing metaphorically and two (and my ducks aren't in a row yet): I'm interested in a cross-couple differential out design that uses only N-channel JFETs and NPN follower or only N-channel JFETs (for a headphone amplifier). Again, why? "Sounds" good to me. I planned to sketch this out for another thread. I wonder if the N-channel and NPN components tend to be better, why they aren't just used in a bridged mode (and it may be easier for a headphone amp). In a way, mirror the circuitry East and West (versus North and South). I'll take this to another thread.
JF |
#199 |
To keep it simple:
Dual differential permits use of a dual voltage amplifier; completely symmetrical all around. This looks great and works well. However, and accounting for the minor transfer function differences between NPN and PNP, their distortions largely cancel, and certainly this is true also in the voltage amplification sections. The result of this is that only symmetrically disposed distortions remain - the asymmetrical ones cancel pretty well - and you are left with very low levels of odd order. The single differential input drives the designer towards use of a single-ended voltage amplifier. This creates considerable asymmetrical distortion, or even order harmonics, which is largely diminished by the global negative feedback loop (as are all distortions, regardless of order). This generally means that dual diff will have lower levels of even order, and low levels of odd order. But single diff will have low levels of even and odd; all are produced, however, not just odds, and with reasonably fast GNFB the incidence of these harmonics will progressively lessen with order. The SET sound has progressively lessening harmonics; petering out at around the 5th harmonic. With a well designed GNFB SS amplifier, it is possible to emulate this profile to a certain extent, though the levels of distortion will be typically two orders of magnitude superior to the SET, but with a few more distortion artefacts. My own belief is that it is the recording process which strips away the higher harmonics of recorded music. The SET goes part the way to reconstituting this denuding of the harmonic profile, richening up the sound, literally 'filling' it out. Cheers, Hugh |
#200 | ||||||
I'm not the one who started talking about power amps, output stages and negative feedback. I just went with the flow of the discussion. Quote:
SE is correct, if you want to make an input filter, then put 50-200pf mica or film cap to ground to have a LINEAR capacitance at the jfet input. So I guess I know a little something. Quote:
He's something of an obsession with me. He even goes onto other message boards that I don't participate on and ****es and moans about me. So don't worry. John would be more likely to stop posting here if I left than if I stayed. se |
| Discrete Dual Differential DAC? | dantwomey | Digital Source | 18 | 5th March 2011 06:24 AM |
| single-ended to differential? | gentlevoice | Digital Line Level | 16 | 17th December 2008 06:18 AM |
| Single Differential Non-feedback | lumanauw | Solid State | 3 | 5th September 2004 02:29 AM |
| Differential to single ended... | Bas Horneman | Tubes / Valves | 21 | 2nd April 2003 02:05 PM |
| Page generated in 0.13022 seconds (90.08% PHP - 9.92% MySQL) with 11 queries |
