Old 18th November 2003, 03:14 AM   #141
johnferrier's Avatar
Originally posted by Peter Daniel
I noticed that occasionally they are inactive, but check later, they'll work fine.
Maybe like Vishay's websites. They seem to be operational about 40% of the time. I think they turn their servers off at night (US time). Haven't ran into many sites like theirs.
JF
Old 18th November 2003, 03:28 AM   #142
Default Ya Mon ! 2 stages is Enough !
The 2SJ200/2SK1529 power amplifier which challenges to the limit of 2 stage constitution
[ 1 ] First experimental circuit Generally, the power amplifier, e.g., the first level, the drive step and the output step, furthermore the source follower enters foreward the output step with, is formed with the stage of 3 steps or more, but it can estimate the deterioration of the extent sound where this stage numbers are few that it decreases.
With the experiment which is developed here, the amplifying stage of the past design absolutely necessity?, you try probably to take a second look whether the efficiency which that brings essentially is important.
Fundamental reformation is necessary in restructuring of amplifier constitution, but well is, when like this is, rather than expressing theoretical empty theory, as I of practice principle, as for here even if it is not possible with the meaning be no other choice but to it tries making the amplifier where with you can obtain sufficient efficiency the less stage number and, it just is found, the て something topic you think that perhaps, the new road opens with the calling and the theme which derives from there.
[ 2 ] Revised circuit
[ 3 ]Crss symmetrization circuit
[ 4 ]Emitter follower drive addition
[ 5 ] The first level FET multiple connection
[ 6 ] Output step source follower/overall NFB
[ 7 ]The output step source follower/there is no overall return
[ 8 ] The first level circuit
[ 9 ] カプリオ クアッド circuit
[ 10 ]The PP circuit which utilizes the opposite quality of MOS-FET
[ 11 ] Experiment of intersection type output circuit
[ 12 ] Revised edition voltage amplification circuit
[ 13 ]2SJ200/2SK1529 power amplifier 1st number
[ 14 ]2SJ200/2SK1529 power amplifier 1 reforming
[ 15 ]About 2SJ200/2SK1529
[ 16 ]2SJ200/2SK1529 voltage mirror
[ 17 ]2SK2313 Kanada system
[ 18 ] Invertedtype
[ 19 ] The first level reforming inverted type
[ 20 ] Decrease return source follower inverted type
[ 21 ] ZD level shift system NFB type
[ 22 ] ZD level shift system non return type
Old 18th November 2003, 03:34 AM   #143
Default Re: Ya Mon ! 2 stages is Enough !
Watch out, thought I saw some NFB stuff there. Might be contagious.
Borbely's super buffer and all FET line amp (figs. 7-9) also seem instructive (at least to me):
http://www.borbelyaudio.com/borb502.pdf
JF
Old 18th November 2003, 04:02 AM   #144
For a common drain (output stage(sorta attractive for swinging up (and down)to the rails)) I don't have a way to do 0 feedback (short using xfmrs) .......... any ideas ?
Old 18th November 2003, 04:15 AM   #145
Steve Eddy's Avatar
So you're the guy who writes all the owners manuals for Japanese electronics?
se
Old 18th November 2003, 04:26 AM   #146
Steve Eddy's Avatar
Why stop short of using transformers?
How 'bout something like this:
Old 18th November 2003, 04:59 AM   #147
OK ....... Do you have a description of exactly how your circuit operates .... The bottom half is particularily non evedent to me.
........mike
Old 18th November 2003, 05:10 AM   #148
Steve Eddy's Avatar
........mike
Sure. The transformer provides the circuit's voltage gain. R1 and C1 are a damping network for that particular transformer, giving it a smooth Bessel rolloff. R2 doubles as the transformer's secondary load as well as volume control. The output is a JFET/bipolar Sziklai pair (a complimentary version of the Darlington pair) used as a voltage follower. The bottom half is the same pair used as a current source.
se
Old 18th November 2003, 05:16 AM   #149
how do you get a 'current source' off of the emitter of a xsistor?
i have a tendancy to think of emitters as 'voltage sources'
Old 18th November 2003, 05:26 AM   #150
Steve Eddy's Avatar
Because that PNP bipolar ultimately behaves as an NPN. Or perhaps more accurately, the pair behaves like a single N-type device. Look up "Sziklai pair" or "complimentary feedback pair" or "complimentary Darlington."
se
Discrete Dual Differential DAC? dantwomey Digital Source 18 5th March 2011 07:24 AM
single-ended to differential? gentlevoice Digital Line Level 16 17th December 2008 07:18 AM
Single Differential Non-feedback lumanauw Solid State 3 5th September 2004 03:29 AM
Differential to single ended... Bas Horneman Tubes / Valves 21 2nd April 2003 03:05 PM
Page generated in 0.14548 seconds (79.00% PHP - 21.00% MySQL) with 11 queries
Copyright ゥ1999-2012 diyAudio
