#131 | |
#132 |
is it only usefull for bipolars?
#133 | |
#134 |
I would use it.
After all, it's only one more resistor. And when designing the PCB, it could even make things simplier in some situations. You don't have to make the ground trace go to the 2nd gate, take a resistor to connect the gate to ground |
#135 |
Fred, originally proposed a sophisicated and 'improved' biasing stage. I felt that it was not a 'universal' schematic, because it lacked placement of a source degeneration resistor in the N channel rail. However, Fred is correct in this one specific case with using J109's and K389's. Thanks Fred, I didn't notice the difference between Gm's before, in these two devices. However, if you were using K170's and J75's, the difference would be less, and almost unmeasurable. Personally, in a simple circuit like this, I prefer to use high Idss types and run them as hard as possible. This includes even slightly overbiasing the input devices in the forward direction, under transient peaks. Please think it through, before attacking my comment.
#136 |
diyAudio Moderator Emeritus
As pointed before, I looked at http://www.ne.jp/asahi/evo/amp/J200K1529/report.htm and find many "not-ordinary" designs there. Are they practical design, or just design idea? Has someone have a chat with those Japanese designer, I think they have different spirit about audio amplifier from person like Mr.Pass or Mr.JC.
I learned that Mr.JC is former designer of MarkLevinson. Could anyone give me a brief schematic of what is inside MarkLevinson Ref.No.33 (The 200kg mono power amp)? Does it uses basic schematic like Ref.no.2 or JC-3? |
#137 |
I believe that Mr.Curl did not design the Ref.33.
The Ref.33 is not a complementary design and nowhere as elegant as Mr.Curl's work. It looks more like a parts farm, to quote another member of this forum. Regards, Jam |
#138 |
Check this link to _see_ what'sinside ref 33. http://www.marklevinson.com/image_li...6&productID=12
Use this link for technical overview http://www.marklevinson.com/products...=pa&prod=no33h
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#139 | |
The outside certainly *looks* impressive. The "what's inside" pics seem to be dead currently. JF |
#140 |
I noticed that occasionally they are inactive, but check later, they'll work fine. Those are high res pics, showing even the print on ICs.
I know that some guys don't like ML, but I was always impressed with their engineering. So recently, I bought myself ML38 preamp board. At $140 it seemed hard to refuse. Finally, I have a piece of a cake too.
| Discrete Dual Differential DAC? | dantwomey | Digital Source | 18 | 5th March 2011 07:24 AM |
| single-ended to differential? | gentlevoice | Digital Line Level | 16 | 17th December 2008 07:18 AM |
| Single Differential Non-feedback | lumanauw | Solid State | 3 | 5th September 2004 03:29 AM |
| Differential to single ended... | Bas Horneman | Tubes / Valves | 21 | 2nd April 2003 03:05 PM |
| Page generated in 0.10571 seconds (85.14% PHP - 14.86% MySQL) with 11 queries |
