Old 17th November 2003, 06:31 PM   #111
Bricolo is offline Bricolo  France
Bricolo's Avatar
Originally posted by PRR
> I thought that dif pairs had a very high gain.
Voltage gain to one output is one-half of the same device working grounded-cathode (or whatever).
On another forum I just pointed out that if you have two triodes, cascading them gives 2*Mu more voltage gain than the same tubes as a diff-pair.
Diff-pairs are useful in high-gain DC amplifiers because the diff-pair has near-zero DC offset. They are often useful in audio with NFB because you get two "identical" inputs. They also avoid cathode bypass capacitors which are often problematic.
The diff-pair has half the gain of a single device, but using BJT, Pentodes, or cascoded FETs or Triodes the useful gain is really limited by stray leakage and capacitance, and may be further limited by overall NFB stability consideration.
If you take both outputs of a diff-pair (either two outputs or a current-mirror turn-around), the gain is identical to a single device.
Understood.
Thanks for the explanations
Old 17th November 2003, 06:55 PM   #112
Default Re: Tail wagging the dog
Originally posted by Fred Dieckmann
"To have it run in the center of it's operating range with the given resistor values.."
Vary the resistor values. Go read
http://www.borbelyaudio.com/ae599bor.pdf
http://www.borbelyaudio.com/ae699bor.pdf
and learn to bias jfets.
To maintain the simplicity of the circuit (keeping the gain, Iq, etc. equal without the use of source resistor bypass caps) it seems a better approach to me to select jfets. IMO
Old 17th November 2003, 06:56 PM   #113
Originally posted by john curl
Folks, please get your ducks in a row about this circuit.
Personally I don't like to use much series resistance in the base of Jfets, BECAUSE it increases the noise of the entire unit. SE is correct, if you want to make an input filter, then put 50-200pf mica or film cap to ground to have a LINEAR capacitance at the jfet input. Then you can reduce the input R to 1K or so.
Input noted and appreciated
Old 17th November 2003, 07:14 PM   #114
You might want to revue that article yourself. (Thanks )
He suggests selecting devices.............mike
Old 17th November 2003, 07:17 PM   #115
diyAudio Retiree
"Personally I don't like to use much series resistance in the base of Jfets"
Don't you mean gate?
I also like to use input filters with the series resistor the value of the characteristic impedance of the interconnect. this filters RF and helps to terminate the interconnect at high frequencies. This obviously calls for the use low impedance drivers but eases the requirements on build out resistors. I still think that a gate resistor of maybe the 100 ohm to 1K is not a bad idea to damp out RF resonances between device capacitance and trace and wiring inductance. Voicing the sound of tube circuits by the value of the grid resistor is a pretty well know design trick. I find that well damped circuits at RF frequencies often sound better and more consistent. I think these values shouldn't have too much effect on line level and power amps noise figures. I remember a recent thread extolling the virtues of JFETs for low noise for moderately high source impedances. The Noise Figure graph for the 2SK389 shows the device noise starting to dominate the resistor noise for impedances below around a few thousand ohms if I am not mistaken.
Old 17th November 2003, 07:25 PM   #116
diyAudio Retiree
"He suggests selecting devices.............mike"
I select devices too, but you have know what you selecting for. To get a specific
value of quiesent current, you have to adjust the source resisitor. I think if you measure a handful of Jfets from the same bias group (GR BL or V) you will be suprised at the variations in Idss.
Old 17th November 2003, 07:41 PM   #117
With a given source resistor, load resistor, and PS, Iq can be matched simply by substituting devices until the (standard (of your choice)) quiessent drain voltage is attained. I think perhaps we're both saying the same thing from differant points in the design cycle.........mike
Old 17th November 2003, 08:07 PM   #118
PMA is offline PMA  Europe
PMA's Avatar
Mike, tell me, what is the Vgs voltage of the Mosfets. Usually about 4V, isn't it? And they are biased by "large green LED diode" in your schematics, is it correct?
Old 17th November 2003, 08:22 PM   #119
These (lateral) mosfets have a much lower threshold voltage than the IR types. The led has ~1.65 volts forward voltage, so each output sees ~0.8 V 'enhancement'. Not class A, but a nice warm AB. ~160ma.
Old 17th November 2003, 08:31 PM   #120
diyAudio Retiree
Question The hard way.........
"I think perhaps we're both saying the same thing from differant points in the design cycle.........mike"
No we are not. You are have to sort through a lot of jfets to find a specific Idss.
Matching a couple Jfets for Idss greater than the desired bias current value and putting a trim pot to select to desired current is so much easier, that this is a no brainer. Sort a through few dozen Jfets to find a specific value and you will find out the hard way.......
Discrete Dual Differential DAC? dantwomey Digital Source 18 5th March 2011 07:24 AM
single-ended to differential? gentlevoice Digital Line Level 16 17th December 2008 07:18 AM
Single Differential Non-feedback lumanauw Solid State 3 5th September 2004 03:29 AM
Differential to single ended... Bas Horneman Tubes / Valves 21 2nd April 2003 03:05 PM
Page generated in 0.13539 seconds (89.02% PHP - 10.98% MySQL) with 11 queries
