Old 17th November 2003, 04:55 PM   #101
Originally posted by Bricolo
what scematic are you talking about?
Old 17th November 2003, 05:01 PM   #102
Originally posted by PMA
I am sorry I meant 10kHz - 20kHz, as THD is usually worse at higher frequencies.
I don't remember if I did 20k but did do 10k (don't have the analyzer any more). Also (and I think importantly) the distortion was ~same at all levels........mike
Old 17th November 2003, 05:17 PM   #103
PMA is offline PMA  Europe
PMA's Avatar
Pretty confusion - I was speaking about image at Post No.81.
Old 17th November 2003, 05:23 PM   #104
That one is in the conceptual stage. Should sound good though.
Old 17th November 2003, 05:27 PM   #105
http://www.ne.jp/asahi/evo/amp/J200K1529/report.htm
Oops ....... Somebody did it .....
Old 17th November 2003, 05:36 PM   #106
Bricolo is offline Bricolo  France
Bricolo's Avatar
Originally posted by hitsware
The 2SK170 has to be selected, but selected for what? I don't see the reason for it, there's no "matching" required (no dif pair, no multiple output transistors...)
Old 17th November 2003, 05:42 PM   #107
To have it run in the center of it's operating range with the given resistor values.............jfets do vary somewhat
Old 17th November 2003, 06:03 PM   #108
PRR is offline PRR  United States
PRR's Avatar
> I thought that dif pairs had a very high gain.
Voltage gain to one output is one-half of the same device working grounded-cathode (or whatever).
On another forum I just pointed out that if you have two triodes, cascading them gives 2*Mu more voltage gain than the same tubes as a diff-pair.
Diff-pairs are useful in high-gain DC amplifiers because the diff-pair has near-zero DC offset. They are often useful in audio with NFB because you get two "identical" inputs. They also avoid cathode bypass capacitors which are often problematic.
The diff-pair has half the gain of a single device, but using BJT, Pentodes, or cascoded FETs or Triodes the useful gain is really limited by stray leakage and capacitance, and may be further limited by overall NFB stability consideration.
If you take both outputs of a diff-pair (either two outputs or a current-mirror turn-around), the gain is identical to a single device.
Old 17th November 2003, 06:05 PM   #109
diyAudio Retiree
Lightbulb Tail wagging the dog
"To have it run in the center of it's operating range with the given resistor values.."
Vary the resistor values. Go read
http://www.borbelyaudio.com/ae599bor.pdf
http://www.borbelyaudio.com/ae699bor.pdf
and learn to bias jfets.
Old 17th November 2003, 06:31 PM   #110
Folks, please get your ducks in a row about this circuit.
Personally I don't like to use much series resistance in the base of Jfets, BECAUSE it increases the noise of the entire unit. SE is correct, if you want to make an input filter, then put 50-200pf mica or film cap to ground to have a LINEAR capacitance at the jfet input. Then you can reduce the input R to 1K or so.
Discrete Dual Differential DAC? dantwomey Digital Source 18 5th March 2011 07:24 AM
single-ended to differential? gentlevoice Digital Line Level 16 17th December 2008 07:18 AM
Single Differential Non-feedback lumanauw Solid State 3 5th September 2004 03:29 AM
Differential to single ended... Bas Horneman Tubes / Valves 21 2nd April 2003 03:05 PM
Page generated in 0.11386 seconds (82.26% PHP - 17.74% MySQL) with 11 queries
