Old 16th November 2003, 11:22 PM   #91
Originally posted by PMA
Simple is good, but not the best. This amp (post 81) will have pretty high distortion, driving gate-source capacitance of the Mosfets.
I've done something simular (single ended 2sk170 driving Hitachis with no feedback) and got ~0.6% THD 20 to 20k. Not as bad as one would expect. (or get with IR types) IMO .... mike
Old 17th November 2003, 04:44 AM   #92
The one and only
Nelson Pass's Avatar
Every type of device has it's own sweet spot(s). Don't
substitute devices into the same circuits and imagine that
you have a real comparison.
Old 17th November 2003, 05:16 AM   #93
Ya Mon .... Forgot to mention used the Hitachis as followers ...
Old 17th November 2003, 05:33 AM   #94
Originally posted by john curl
The circuit should work, just as it is. Gate resistors are most probably optional on this design. Why? I don't know why you like gate resistors of jfets. All it does, in this case, is to make the input more noisy.
If'n you use a gate resistor with a jfet (at the input) ..... You get a rolloff that completely negates any kind of TIM .... I use 10K with 2sk170 .......
Old 17th November 2003, 06:10 AM   #95
Steve Eddy's Avatar
Hmmmm. But since FET input capacitance is so non-linear, wouldn't such a high value input resistor just acerbate the problem and produce greater amounts of high frequency distortion which could fold back down into the audio band?
A shunt RC network would ultimately be preferable, yes? Assuming of course that one's goal is optimal objective performance.
se
Old 17th November 2003, 03:44 PM   #96
It seems that would be the case, but in practice it works. It's a differant ball game than with something like the mundo IR type fets where the output (drain) reflects back to the gate. Using a 10kHz squarewave as referance, I get nice smooth response.
Yes, theorieticly. But sometimes to me super simple elegance in the schematic can outweigh other factors. I must say however I've not aurally A-B 'd the 2 approaches. Usually my squarewave approach is pretty dependable though...........mike
Old 17th November 2003, 04:03 PM   #97
PMA is offline PMA  Europe
PMA's Avatar
A question is if we consider THD of 0.6% to be low or high. For me that is high. How is the THD at 10 - 20kHz? Did you measure IMD - probably more problems with Mosfet's non-linear input capacitance.
Old 17th November 2003, 04:22 PM   #98
For a 0 feedback (global anyways) amp, I consider it slightly high but workable. No I didn't measure IMD (or THD below 20Hz), so that could be bad, but again I've always had good results using carefull scrutiny of squarewave response.
Old 17th November 2003, 04:37 PM   #99
PMA's Avatar
I am sorry I meant 10kHz - 20kHz, as THD is usually worse at higher frequencies.
Old 17th November 2003, 04:39 PM   #100
Bricolo is offline Bricolo  France
Bricolo's Avatar
what scematic are you talking about?
Discrete Dual Differential DAC? dantwomey Digital Source 18 5th March 2011 07:24 AM
single-ended to differential? gentlevoice Digital Line Level 16 17th December 2008 07:18 AM
Single Differential Non-feedback lumanauw Solid State 3 5th September 2004 03:29 AM
Differential to single ended... Bas Horneman Tubes / Valves 21 2nd April 2003 03:05 PM
Page generated in 2.77467 seconds (4.93% PHP - 95.07% MySQL) with 11 queries
