why do old amps has sleeve on the resistors pins... - diyAudio
Old 31st October 2012, 03:01 PM   #1
Default why do old amps has sleeve on the resistors pins...
http://i51.tinypic.com/154vldz.jpg
there is a sleeve on the resistors pins what is the reason behind it?
why its not bein used now?
does it makes any difference?
Old 31st October 2012, 03:25 PM   #2
Hi rhythmsandy,
Those are ceramic stand-off pillars and are used to help prevent heat being conducted along the resistor leads and into the PCB. They work by maintaining a distance between a hot component and the board while retaining a degree of rigidity and support.
currentflow
Old 31st October 2012, 03:39 PM   #3
expert in tautology
bear's Avatar
actually a great idea in any case where there are hot resistors above a PCB...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 31st October 2012, 03:39 PM   #4
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Originally Posted by currentflow View Post
Hi rhythmsandy,
... and give more air to evacuate the heat into the atmosphere.
If anything can go wrong, it will.
If anything just cannot go wrong, it will anyway.
Old 31st October 2012, 03:50 PM   #5
... and to increase the manufacturing costs!
currentflow
Old 31st October 2012, 03:58 PM   #6
Yeah, but it is other problem.
Old 31st October 2012, 04:18 PM   #7
DRC is offline DRC  United Kingdom
DRC's Avatar
The heat issue is less of a problem with modern PCB materials. The old paxolin type scorch really easily. The downside of standoff is both mechanical (just look at those ceramic coffins on the OP image) and a slight increase in the loop area for inductive pickup.
dc
Old 31st October 2012, 05:06 PM   #8
true thanks for the replies guys...
Old 31st October 2012, 07:48 PM   #9
expert in tautology
bear's Avatar
I'll take the slight increase in loop area over excess temp in my resistors. If you've got a circuit where that makes any difference, the layout and parts are going to be way different, I would think.
_-_-bear
_-_-bear
Old 1st November 2012, 08:13 AM   #10
jitter is offline jitter  Netherlands
jitter's Avatar
I believe it is standard practice in (industrial) electronics manufacturing to mount leaded power resistors somewhat above the pcb. One way to do that is to use those ceramic standoff pillars, but that's indeed a more time consuming method.
Another way of doing it is to bend and indent the leads in a specific place such that the leads do not drop through the holes in the pcb all the way. This bending and indenting is done automatically using gear like this, and after setting it up doesn't require much labour.
You end up with components that don't need more time to mount that those without a standoff. The only drawback is that without the ceramic standoff pillars the resistors bend more easily if the pcb is handled carelessly.
Why don't chip amps use emitter resistors? EWorkshop1708 Solid State 18 27th January 2008 01:52 PM
Feedback resistors with 'drop-in' replacementop-amps homemade Parts 8 14th February 2007 03:32 AM
What's with removing the sleeve off caps? homer09 Parts 5 26th February 2005 08:48 AM
Anode Resistors on PPP Amps gingertube Tubes / Valves 9 21st February 2005 04:28 PM
+/- supply resistors on op amps? crippledchicken Solid State 6 4th October 2004 08:40 PM
Copyright 1999-2017 diyAudio
