Parts quality does matter, yes, but..
Old 29th October 2012, 10:57 PM   #1
hiktaka is offline hiktaka  Indonesia
hiktaka's Avatar
Default Parts quality does matter, yes, but..
on some designs, it doesn't matter as much as on another designs.
I've built some DIY; but I found that sound difference between exotic parts vs
cheap parts aren't same for all designs.
Of few that i've built:
JLH 10W is the least sensitive, even on the breadboard using scrap parts sound pretty good.
Mini-Aleph and F5 are moderately parts-affected. Difference are noticeable, but with cheap parts, it's not that bad.
The most picky for parts is Hiraga Lemonstre. Change a resistor or two (with cheap replacement) and degrade badly.
Any opinions?
Thanks,
Old 29th October 2012, 11:12 PM   #2
DF96 is offline DF96  England
I will get shouted at for saying this, but my opinion is that given reasonably decent component quality then the better the circuit design the less it will be fussy about components.
Old 29th October 2012, 11:34 PM   #3
counter culture is offline counter culture  United States
Some designs require matched parts, some do not. Some parts of circuits are critical with regard to what type of part is used, some are not.
In some places it's not clear exactly what influence part selection may have and it's difficult anyway to know whether the reputations some parts enjoy is deserved.
I pick parts according to known factors affecting functionality and by price (how cheap can I get it). What else can one do apart from abandon oneself to the vagaries of internet mythology? Not my cup of tea, vagaries.
Old 29th October 2012, 11:59 PM   #4
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Manufacturers will aim towards a fair design with fair parts. ASFAIAC DIY is concerned it will always be a compromise. To a certain degree parts will make a difference, that should be counteracted by good design.
I've got an Aleph 4 where the specified capacitors were very poor in relation to reasonably priced alternatives. Resistor changes in this deisgn make no difference IMHO, as long as you start with half decent components, this one uses 1% vishays from RS.
Any capacitor in the signal path will make a difference but you don't have to GO STUPID.
I fronted mine with a B1. There was ne real difference between PIO's and good MKPs in the signal path.
Old 30th October 2012, 12:13 AM   #5
CBS240 is offline CBS240  United States
CBS240's Avatar
It all depends on the function. A general purpose transistor is just that, general. Price depends on other factors. There is a SOT-563 duel transistor package that I use quite a few of. They are generally ~20 cents ea. I found my supplier has a different brand with similar properties for 5 cents. 2.5 cents per transistor is not bad. One could argue that resistor matierial has different noise specs. It depends on the function of the resistor in the circuit as to wether or not it makes a difference. Some resistive material can catch fire, others do not.
All the trouble I've ever been in started out as fun......
Old 30th October 2012, 01:18 AM   #6
lanchile is offline lanchile  United States
lanchile's Avatar
I go for Design and parts quality! combine both and you get a killer amp
Old 30th October 2012, 01:21 AM   #7
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i am not shouting, in fact i agree with you whole heartedly....
"it is not much the hatchet, but the Indian throwing it...."
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 30th October 2012, 02:42 AM   #8
Ian Finch is offline Ian Finch  Australia
This might just be the corollary of DF96's post above but, as a general observation, simple design amplifiers do seem critical on component choices, grades and quality. More elaborate designs, containing refinements that ensure optimal circuit operation, are much less so.
Importantly, simple amplifiers can often have very unique and desirable sound qualities, so it is then a matter of choosing what sort of amplifier you really want and this leads to a trade-off of parts cost against complexity. Through ignorance, and I guess the conclusion that expensive parts must then result in better sound quality, some guys just buy the biggest and most expensive parts and brands available in the hope that this will confer better sound quality.
I think that's where the idea falls apart.
Ian
Old 30th October 2012, 05:38 AM   #9
Coconuts 500 is offline Coconuts 500
Be kind to your wallet; do more blind testing. Observe how the myth that price and performance are related comes crashing down. Enjoy your new found enlightenment.
Old 30th October 2012, 09:43 AM   #10
hiktaka's Avatar
IMO, here are some of parts function that have significance of by parts quality
- Input C: very important, very noticeable difference.
- R in signal path: noticeable, but a cheap one won't be bad.
- R & C in bias circuit: doesn't matter.
- Output cap: the big one doesn't matter, oddly bypass C (with smaller uF) does.
- Semiconductor: in a simple design, yes. In a complex design, no.
- Passive load choke, output L: should be, I have less experience.
- PSU parts: Trafo should have biggest impact
I won't even go to talk about cables & interconnects
Thanks.
Parts quality does matter, yes, but..Hide this!Advertise here!
The best quality parts and suppliers? Fivetide Parts 12 20th February 2012 09:51 AM
Quality Components and Parts dacapitan Parts 0 28th January 2011 03:45 PM
Does quality of negative voltage regulation matter Dr.H Solid State 2 23rd July 2009 01:10 PM
How much does the quality of a sub amp matter? Javaman Multi-Way 7 15th February 2003 07:25 PM
Does component quality matter? r_s_dhar Analogue Source 15 17th July 2002 07:42 PM
Copyright ©1999-2017 diyAudio
