Sources for TO220 heatsinks?
Old 29th October 2012, 09:17 PM   #1
Fusion916 is offline Fusion916  United States
Default Sources for TO220 heatsinks?
It seems digikey doesn't sell the really big audio heatsinks you typically see in high power applications. The biggest TO220 heatsink I have found on digikey is this one:
RA-T2X-64E Ohmite | RA-T2X-64E-ND | DigiKey
Old 29th October 2012, 10:19 PM   #2
zlast is offline zlast  United States
Send a message via AIM to zlast Send a message via MSN to zlast Send a message via Yahoo to zlast
Default Heatsink
[QUOTE=Fusion916;3220182]It seems digikey doesn't sell the really big audio heatsinks you typically see in high power applications. The biggest TO220 heatsink I have found on digikey is this one:
Might help if you gave some information about your application and heat dissipation. You might check with Steve at apexjr.com
none
Old 30th October 2012, 02:08 AM   #3
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
http://www.diyaudio.com/forums/swap-...heatsinks.html
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 30th October 2012, 02:38 AM   #4
stratus46 is offline stratus46  United States
If you're using them for regulators you'll be fine. If you're running parallel bipolar transistors - even with low value emitter resistors - you DON'T want to use them. Parallel bipolar transistors REQUIRE a common heatsink to prevent thermal runaway. It would be even better if _all_ the bipolar power transistors in a channel were on one large heatsink.
G
Old 30th October 2012, 04:07 AM   #5
Ian Finch is offline Ian Finch  Australia
One look at a TO220, or in fact any plastic pack transistor and the brain should be saying..." It fits on any flat surface".
Don't feel that you need to use a particular type of heatsink for all T0220 transistors unless of course, you can't use a 1/8'' drill.
If only I had listened....
Old 30th October 2012, 05:34 AM   #6
6speed is offline 6speed  United States
6speed's Avatar
The DIY store has 2 and 3U versions, check the amp spare parts area. Some drilling may be required but you can do it.
Sources for TO220 heatsinks?Hide this!Advertise here!
Voltage Sources & Current Sources rascal101 Everything Else 3 13th September 2012 12:56 PM
WTB Fischer SK76-50 TO220 heatsinks Sunsun22 Swap Meet 1 25th February 2010 07:30 PM
sources for caps / resistors / connectors / insulation pads and heatsinks? millwood Solid State 2 11th June 2003 12:42 AM
7812 TO220 regulator little help please strulon Tubes / Valves 19 23rd May 2003 02:54 PM
TO220 5 lead package? trwh Parts 2 5th April 2003 12:03 PM
