Possible to Replace (2*2n3055) with (2*TIP35) in circuit power-amp-super-bridge-120w-by-ic-tda2030a
whats power of amp with this change?
Possible to Replace (2n3055 and TIP36) with (BD907 + BD908) in circuit TDA2030A+ BD908+BD907
I remember BD 249/BD250
With dual 16 V supply @5A
??? Whats Remember?
Vce of BD249 &BD250 IS 45V
The first schematic won't work.
Why ?
mistake schematic or .....
please explanation you
Why ?
If you was to build the circuit and measure the voltage across the emitters of the BD249/50 on one of the amps what would you measure?
The first schematic works ( or used to ) !
I's an application of ST
your better schematic for test(simple) only TDA2030A ??The first schematic works ( or used to ) !
I's an application of ST and oh, yes, there's an error...
please Guide me
paste tda2030a into diyaudio "search" and it comes back with the list of every Thread that has discussed your chip.please send url of good schematic for test TDA2030A (SIMPLE)
There are only 131 results.
Do your own homework yourself !
- REPLACE TIP36 + 2N3055 IN TDA2030A
