Mechanical Transformer Hum
Old 23rd January 2013, 08:07 PM   #31
TANDBERGEREN is offline TANDBERGEREN  Norway
No indication on the type-label on the back side of the amp?
Power consumption?
Is the original power-line fuse present or labelled?
Sooner or later you end up with TANDBERG
Old 23rd January 2013, 09:18 PM   #32
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I doubt whether you actually have a problem.
The proper place for a BGW750 (I've had a lot of them, still warmly remembered) is in a rack, at either far end of a stage, behind a mountain of PA speakers.
Buzz ... !!!! What buzz ???
Are you speaking to ME? SPEAK LOUDER !! CAN'T HEAR YOU !!!!
Old 23rd January 2013, 09:38 PM   #33
Michael F is offline Michael F  Canada
Michael F's Avatar
Power consumption?
15 amps
Old 23rd January 2013, 09:39 PM   #34
Michael F's Avatar
Very true, but not in my case. The hum is just loud enough to be distracting.
Old 10th February 2013, 03:55 PM   #35
Michael F's Avatar
Default Another Update
Not satisfied with the results of my varnish soak, I decided to give the mechanical decoupling method a shot.
I found it interesting that with the xformer removed from the chassis, the hum was practically inaudible!
It took some time to figure out a scheme given the really tight fit within the chassis but I managed to do the following:
Inserted a thin dense foam pad (think mousepad) between xformer and chassis at the two points of contact, the mounting side and bottom, as well as between the xformer and right angled metal shielding plate which covers the top and side of the core.
The xformer was secured like this:
1/4-20 bolt head>metal washer>3/8" rubber grommet sliced down the middle>chassis>foam pad>metal shield>Xformer>other half of sliced grommet>metal washer>nylon nut.
The last half grommets could not be used on the underside of the xformer as there are speednuts mounted there and quite unreachable.
1/4"grommets went between the shielding plate and underside of the chassis.
The result? A significant improvement! It is not totally silent, I suspect a little transmission taking place through the bottom speed nuts but not much can be done about that.
For the moment, the noise level is acceptable. Depending on my level of OCD and or boredom, I may re dip and cook the Xformer when the weather permits.
Thanks to all who chimed in, hopefully this will help someone in the future.
Mechanical Transformer HumHide this!Advertise here!
Mechanical Isolation for a Power Transformer Markhh2 Tubes / Valves 7 10th December 2010 07:15 PM
transformer hum please help s4s4s4 Power Supplies 4 4th May 2008 08:30 PM
Transformer hum? Emubitter Power Supplies 8 21st April 2008 03:17 AM
mechanical hum Bill*B Tubes / Valves 4 30th May 2007 09:42 PM
transformer hum zzz Tubes / Valves 27 4th January 2004 03:58 PM
