Can you test to see if the avalanche knee voltage is more current dependent than a regular zener?
Is this what you meant? The knee of the led in zener mode is not sharp, the true zener is very sharp. The graph below has been manipulated to match the terminal Zener voltage on the top right side of the curves, LED aprox 7.3 volts and Zener 6.2 volts. Current (Y) is at 100mv/ma
Yes, excellent work there. But, that led probably shouldn't be run long term in reverse. There's no zener in there.
Other use:
The top of one of those leds can be sanded/filed flat, clear glued to a CDS and that thing painted black, and presto! handmade optocoupler. That can be used for my clipnipper or a really similar project from Rod Elliot. The settings can be different depending on which CDS is selected, but it is easily doable with parts from Radio Shack.
And, as a detector, the LED does not suddenly switch on and therefore I like the LED better for transparent compressors. Suddenly switch on with zener isn't transparent. But, after enough led's have been strung together for "gentle cushion" (approximately 3 for clipnipper), a zener can be added to the chain as needed to re-scale for more powerful amplifiers.
Thanks.
This is where I am confused, isnt the built in ESD diode a zener?
I don't quite grasp how the non sharp knee is useful. Do you say running the device within the knee currents? On a regular scale the device looks like a regular zener like in my first post.
- High Brightness LED Zener Like Curve
