High Brightness LED Zener Like Curve
Old 26th October 2012, 02:39 PM   #21
avincenty is offline avincenty  United States
How do i do that? With a variable ccs?
Old 26th October 2012, 05:11 PM   #22
indianajo is offline indianajo  United States
indianajo's Avatar
The only advantage I can think of in using this zener, instead of a real one, is that you need a 7 V zener, and you don't want to pay $6 freight to get one. I've been known to stack salvage 1n4148's on top of the 4 values of zeners I keep to make some other voltage.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 28th October 2012, 09:00 PM   #23
Originally Posted by danielwritesbac View Post
Can you test to see if the avalanche knee voltage is more current dependent than a regular zener?
Is this what you meant? The knee of the led in zener mode is not sharp, the true zener is very sharp. The graph below has been manipulated to match the terminal Zener voltage on the top right side of the curves, LED aprox 7.3 volts and Zener 6.2 volts. Current (Y) is at 100mv/ma
Old 28th October 2012, 09:10 PM   #24
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Looks like a pretty lame LED zener, perhaps due to the combination of reverse currents through the two PN junctions.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 29th October 2012, 01:54 AM   #25
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Yes, excellent work there. But, that led probably shouldn't be run long term in reverse. There's no zener in there.
Other use:
The top of one of those leds can be sanded/filed flat, clear glued to a CDS and that thing painted black, and presto! handmade optocoupler. That can be used for my clipnipper or a really similar project from Rod Elliot. The settings can be different depending on which CDS is selected, but it is easily doable with parts from Radio Shack.
And, as a detector, the LED does not suddenly switch on and therefore I like the LED better for transparent compressors. Suddenly switch on with zener isn't transparent. But, after enough led's have been strung together for "gentle cushion" (approximately 3 for clipnipper), a zener can be added to the chain as needed to re-scale for more powerful amplifiers.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 29th October 2012, 02:37 AM   #26
Thanks.
This is where I am confused, isnt the built in ESD diode a zener?
I don't quite grasp how the non sharp knee is useful. Do you say running the device within the knee currents? On a regular scale the device looks like a regular zener like in my first post.
Old 29th October 2012, 03:32 AM   #27
sofaspud's Avatar
What does "regular scale" mean? What is your explanation for the difference in screenshots between post#1 and post#23?
The non-sharp knee may just mean that the LED zener is doped simply for LED protection, not for any sharp knee regulation-type function.
Old 29th October 2012, 03:47 AM   #28
In post 1 you see the full swing from a 6vrms ac drive, where you can see forward and reverse regions. Post 23 is only a zoom of the zener knee portion, see the grid scales,20mv on the x and 100mv/ma on the y.
Old 29th October 2012, 03:59 AM   #29
sofaspud's Avatar
Thanks, that's what I thought but wanted to be sure.
Old 29th October 2012, 04:13 AM   #30
This may be clearer
Left one is the LED connected in reverse.
High Brightness LED Zener Like CurveHide this!Advertise here!
How do you determine the brightness of an LED? Headfi Fanatic Parts 5 2nd August 2010 10:13 PM
zener diode high performance Stefanoo Pass Labs 2 16th January 2007 09:11 AM
