Old 24th October 2012, 04:01 AM   #1
Default help with adcom 555 amp left channel death
hi. im probably not qualified to be on this thread seeing as ive never even taken the cover off any of my equipment, but here goes..I was hoping someone could help with a recent problem with my Adcom 555. i have owned it for 20 yrs or so and been more than happy with it...no modifications, no problems till now. The power switch stopped working ages ago but just have it plugged into the switched outlet on pre amp to turn on off.
recently however, the left channel has stopped working. thiught st first it was the cheap speaker selector it was hooked to, but tried switching channels from preamp as well as bypassing preamp altogether by hooking source dirctly to amp, to no avail. speakers are fine, but nothing coming out of left channel.
theres only one repair shop in town that works on these and they have a several week month backlog...
thanks
Old 24th October 2012, 05:13 AM   #2
kevinkr's Avatar
Moved to solid state
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 26th October 2012, 12:57 PM   #3
djk is offline djk
djk's Avatar
Pop the lid and check the fuses.
Candidates for the Darwin Award should not read this author.
Old 26th October 2012, 01:22 PM   #4
SY's Avatar
99% chance that's it. If you have a voltmeter, you might want to check the output for DC- if there's more than a few millivolts, you've almost certainly lost one of the power supply rail fuses.
Make sure it's unplugged and that the filter capacitors have had a few minutes to discharge before poking your fingers around inside!
If there's a sucker born every minute, where do the rest of them come from?
Old 19th November 2012, 05:25 AM   #5
not sure how to locate fuses and what tomreplace with?
Old 19th November 2012, 09:42 AM   #6
SY's Avatar
Open the lid. If it's not obvious, close the lid and let someone else do it- you don't want to risk damaging it in an expensive way, or for that matter, damaging yourself!
Adcom GFA-555 Left Channel Buzz Dudeman258 Pass Labs 18 14th March 2013 01:25 PM
Adcom GFA-555 Left Channel Buzz Help Dudeman258 Solid State 0 6th May 2011 08:29 PM
Adcom GFA-555 Mk1 channel noise Dudeman258 Solid State 6 16th April 2011 06:12 PM
Adcom GFA-555 mk2 left slight cracking in high freq lga775 Solid State 2 4th December 2010 11:30 AM
Adcom 555 II channel failure computeruser Solid State 89 14th May 2006 06:33 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
