Class i - Page 4 - diyAudio
Old 24th November 2012, 10:41 PM   #31
expert in tautology
bear's Avatar
Kevin, private emails are not something to air on this forum, and bad form on any other, imo.
Sorry that you took my suggestions and inquires the way you have. My interest in what you sell is/was genuine.
I think I am out of this thread for a while... thanks.
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 6th December 2012, 07:36 PM   #32
Struth is offline Struth  Canada
Banned
Hi Guys
The William Chater patent (US5,055,797) shows a bias control method using a differential amplifier monitoring the floating Re's of a mosfet output stage, feeding a precision rectifier and integrator, in turn manipulating the mosfet drive stage. AC signal is essentially ignored.
The method above is a bit complex. Self's class-A bias servo is simpler and is discrete. Other current-monitoring control circuits require just two BJTs and are unaffected by the signal.
The MF circuit is simple but tries to do too many things all at once which restricts performance.
The class-i "engine" is clever but requires matched devices to work well.
Lineup's diamond feedback circuit works very well at reducing crossover distortion if you wish to check out his thread regarding a power buffer idea.
Have fun
Kevin O'Connor
Old 7th December 2012, 11:29 PM   #33
expert in tautology
bear's Avatar
attached is the pdf of the Chater patent.
He speaks of a "turn-off transient suppressing means" and also to "...substantially eliminate crossover distortion..."
There was another amp on here that nobody could figure out if it really had immunity from turn off - trying to recall the fellow's name... it had been a commercial product. If I remember I'll post.
Coming up with a "better" and more robust method of making the class i method would be nice.
_-_-bear
Old 8th December 2012, 04:14 AM   #34
Banned
Hi Guys
Has anyone seen the fourth part of the class-i article? It is supposed to present a practical constructed circuit.
The circuit idea is very clever in the British context, and the pitfalls all seem heavier than what gets "fixed". The previous references I gave mostly produce class-A output stages, but do not necessarily have to.
There was discussion elsewhere about the Super-A biasing. Did anyone every measure such an amp? or simulate it?
Have fun
Kevin O'Connor
Old 10th December 2012, 10:28 PM   #35
expert in tautology
bear's Avatar
subscribe to Jan Didden's Linear Audio, it has the complete article... more is yet to be published as a follow up i am led to believe...
_-_-bear
_-_-bear
Old 10th December 2012, 11:06 PM   #36
Banned
Hi Guys
One man's "substantially eliminated" is another man's "zero artifacts". The proof is in the building and measuring. Apart from being a 100% mosfet signal path, it does not look like there should be anything to keep Chater's approach from doing what it is intended to do.
Have fun
Kevin O'Connor
Old 10th December 2012, 11:48 PM   #37
expert in tautology
bear's Avatar
Is Chater's approach "error correction" or is it "non switching"?
One tries to fix it "after" the other "before".
_-_-bear
_-_-bear
Old 11th December 2012, 12:59 AM   #38
Banned
Hi Guys
Bear, is your question rhetorical?
Taking it at face value, Chater's method is in the "nonswitching" category. Elvee dismissed the method as "sampling" and being "delayed in time" when someone asked about this on the circlophone thread. I think that because there is an integration involved, Elvee saw it as not being instantly effective. I don't think that is actually a problem if crossover distortion is eliminated, and there are definitely simpler methods.
Self's method is similar inasmuch as Vq is sensed directly, but his approach uses a floating bias control circuit so is overall simpler and has no time constants. The methods shown in my books are even simpler.
Have fun
Kevin O'Connor
Old 11th December 2012, 03:35 AM   #39
expert in tautology
bear's Avatar
Quite frankly I am unclear on what this method is. I did not see your posts on the circlophone thread, I stopped looking at that some time back, and there are too many threads that i am trying to keep up with now... so the question is simply this. Are the methods you are referring to preventing cut off of each half cycle of the PP output stage or are they adjusting the overall bias over some time constant that is greater than one half cycle?
I can't determine this by simple inspection of the schematic(s).
If there is a way to do it by simple inspection, I'd love to have it explained.
_-_-bear
_-_-bear
Old 11th December 2012, 03:54 AM   #40
wahab is offline wahab  Algeria
_-_-bear
New Class A, Super-A, Non-Switching : need a revival ?
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 06:49 AM
Collection of Class B topologies <100mA Idle and Sound closest by Class A tiefbassuebertr Solid State 37 27th July 2012 08:04 AM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Copyright 1999-2017 diyAudio
