Class i - Page 13 - diyAudio
Old 28th December 2012, 04:08 PM   #121
Waly is offline Waly  Umm al-Qaiwan
Waly's Avatar
Originally Posted by Edmond Stuart View Post
I wrote: gm ~=Ic/26mV and notice the tilde. Whether this equation is correct doesn't matter, as I didn't use it for any calculation at all.
~ doesn't mean on my side of the channel over +/-100%. The equation wouldn't matter if everything would be linear, which is not.
Otherwise, just stay in your simulation world. It may look like you are always right (in particular when not being specific on all the details, like schematics, models, methods, etc...), and also reading on a topic (I already suggested some good references) is not required.
I think it's time to update again your **** list.
Old 28th December 2012, 05:04 PM   #122
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by Waly View Post
The usual confusion between a small signal, linearized, and a large signal analysis. gm=Ic/26mV holds for small signal only.
Yes, it is directly derived from the exponential junction equation, it is the slope of the curve at that particular Ic. It is therefore valid only for infinitesimal variations around that point.
But more generally, if a gm remains constant for a range of currents, this implies that the element is linear for that range
There is no simple way to calculate the large signal transconductance. The large signal analysis of an emitter follower with Re does not have any known analytical closed solution.
It makes no real sense for a highly non-linear element
Whether this equation is correct doesn't matter, as I didn't use it for any calculation at all. My simulator did the calculations, which also takes care of large signal and other effects. And please don't start whining again about the accuracy of simulators. For the purpose at hand they are accurate enough.
The point is that the composite gm of the bipolar output trannies plus emitter resistors did not reveal the gm doubling at large currents. That means you can't use it for explaining the distortion. Perhaps you forgot it, but we are talking about the real cause of distortion: is it bias voltage modulation or is it gm modulation. According to my last plot (black curve) it is not gm modulation.
The devil is in the details, in this case the practical ones: the various parameters used for the simulations.
For an ideal transistor pair having no Re, internal or external, a non-linearity will already be present: for the pair to remain linear, the sum of the collector currents would need to remain constant, but that is never the case, even in the "class A region". With a constant base bias, instead of a constant sum of Ic's, we have a constant sum of the logarithm of the currents.
For small excursions around the quiescent state, this is more or less equivalent, but as soon as one current becomes large, discrepancies occur.
Let us take a numerical example: if the bias voltage is such that it establishes an Iq of 100mA, an output current causing a shift (bias modulation if you like) of 20mV will ~double the current in one of the transistor, resulting in Ic=200mA, and it will halve the current in the other one, but that is not enough: to keep the sum constant, it would need to be 0. We therefore have a 50mA excess, and a corresponding increase in the transconductance.
In this case, the gm is minimal at the equilibrium, and increases proportionally to the excursion.
If emitter resistors are added, this effect can be mitigated and even reversed, but they will not make the OPS linear: with devices obeying an exponential law, that is an impossibility. Only square law devices could achieve that
That is precisely because the sim is accurate enough that "unexpected" effects show
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 28th December 2012, 05:05 PM   #123
Edmond Stuart's Avatar
Walter, your reference, this one: http://users.ece.gatech.edu/mleach/papers/classab.pdf doesn't cover the topic we are discussing here. So if you think it's relevant then you are missing the point completely.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het licht…(H.M. van Randwijk)
Old 28th December 2012, 05:52 PM   #124
Elvee, I know this already, but it's beside my point. Moreover, my simulator takes care of all these matters.
I'm talking about the difference between the 'green' and the 'black' incremental gm (see post #118).
The first one is simply gm = delta Io / delta ( Vi - Vo ), where Vi = ( Vb1 + Vb2 )/2 and Vb1 and Vb2 are the base voltages of the top respectively bottom output tranny. Notice that ( Vb1 + Vb2 )/2 = Vb2 + Vbias/2 = Vb1 - Vbias/2. IOW, the bias voltage has been taken into account.
While the second one consists two gm's (of top resp. bottom tranny) summed together:
gm = delta Ie1 / ( delta( Vb1 - Vo ) + delta Ie2 / delta( Vo - Vb1 ) ), were Ie1 and Ie1 are the emitter currents of top respectively bottom output tranny
In this case the bias voltage has not been taken into account.
Not surprisingly, we get two different gm figures. Now, which of the two is correct, the green one or the black one?
E.
PS1: Vb1 and Vb1 are base voltages WRT ground, thus not Vbe.
PS2: Walter, you are not supposed to comment on this post.
PS3: I corrected the equation for the black gm.
Old 28th December 2012, 06:56 PM   #125
Elvee's Avatar
Could you post the schematic with nodes a, b, c and resistors R8, R9, R10 explicitly shown?
Seeing things graphically helps lift ambiguities
Old 28th December 2012, 07:52 PM   #126
Okay, here it is:
Old 29th December 2012, 06:48 AM   #127
As pointed out in the EDN article, the class I schematic is the same as fig 4 of USPTO 4,595,883 from 1986 (Pioneer). It does simulate well on Simetrix
Old 29th December 2012, 08:30 AM   #128
Elvee's Avatar
Okay, here it is:
I don't get the same anomaly: the two curves are perfectly overlaid.
I see two possibilities: your V(A) varies with respect to V(B): the two expressions are equivalent provided dV(A,B)=0
Another possibility is an ambiguity in the sign convention in the simulator resulting in quantities subtracting instead of adding under certain conditions.
Old 29th December 2012, 10:15 AM   #129
If youre interested in applying it just buy pioneer PA0016 Ic which is available at around 15 euros. It will save you some complexity.
Old 29th December 2012, 10:52 AM   #130
Hi Elvee,
Of course the two curves are just the same, simply because this is an ordinary class-AB OPS without sliding bias.
If you are in the mood, you could repeat the sim with sliding bias. To keep it simple, just replace V4, by a CCVS that keeps I(R8)*I(R9) constant. For an idle bias of 100mA for example, set the product at 0.01.
Of course such circuit is not exactly the same as a PA0016, though it comes close as far as bias concerns.
Here's an example with mosfets and a CCCS that keeps product of source currents constant: CDCP
E.
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 06:49 AM
Collection of Class B topologies <100mA Idle and Sound closest by Class A tiefbassuebertr Solid State 37 27th July 2012 08:04 AM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Copyright ©1999-2017 diyAudio
