How to calculate breeder resistor value? - diyAudio
Old 31st October 2003, 04:38 PM   #1
chris ma's Avatar
Default How to calculate breeder resistor value?
After I turned off the amp, there is always some DC value at the binding posts, that is without connecting to any speaker though.
I tried some white resistors to drain it while measuring it as well the DC value go back up to 50mV as soon as the white resistor is disconnected from the binding posts.
I remember I read something like breeder resistor intalled in the PSU to drain power. How do I intall it and how to calculate power and ohm value for the resistors? I am using CLC unregulated power supply for a Class A amp.
Thanks in advance,
Chris
Old 31st October 2003, 05:06 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Hi Chris,
This looks like a neat little circuit. It's a bit more then a simple resistor. The advantage is that the resistor only works when powering off the unit.
http://hjem.get2net.dk/aaholm_audio/.../discharge.htm
/Hugo
Old 31st October 2003, 05:50 PM   #3
grataku is offline grataku  United States
that would be called a "bleeder" resistor...
Old 31st October 2003, 05:53 PM   #4
chris ma's Avatar
Thanks Hugo,
That's a neat idea. I already have a small transformer for the soft start relay in the PSU. I can just add a second relay for the bleeder resistor by tapping into the same 12V supply.
grataku,
My typo
Chris
What is the RIGHT way to calculate the Value of the cathode resistor? sgerus Tubes / Valves 22 18th December 2008 08:04 PM
How can I calculate voltage over cathode resistor? Nordic Tubes / Valves 27 30th April 2008 10:44 AM
How to calculate Log pot resistor values? faux_vedette Solid State 1 4th March 2006 01:54 AM
how to calculate feedback resistor Lico Tubes / Valves 7 9th June 2004 05:41 AM
Copyright ©1999-2017 diyAudio
