Pioneer SA 9500 mk 1
Old 22nd October 2012, 03:20 AM   #1
bikey022 is offline bikey022  Singapore
Default Pioneer SA 9500 mk 1
I have a pioneer SA 9500 mk 1 and when i increase the volume to the 2nd click it start to have distortion. May i know what is the problem ? I have changed the transistor in the preamp side. I suspect is the power supply section as i increase the volume it draws higher current causing the distortion.
Old 22nd October 2012, 06:48 PM   #2
amptech is offline amptech  Scotland
Send a message via MSN to amptech
Test the o/p devices... These old amps suffer from bad dry solder and cracked pcbs.... You can apply a signal into the preamp stage and bypass the preamp to check if the o/p stage is at fault...
Pioneer SA 9500 mk 1Hide this!Advertise here!
Aging Pioneer SA-9500 II harley Everything Else 1 25th December 2011 08:52 PM
Pioneer SA 9500II Big_Bill Solid State 15 14th September 2009 01:15 AM
Help With Pioneer SA-9800 Please hifileslie Solid State 1 26th July 2007 02:24 PM
pioneer SA-1520 murat Solid State 2 23rd February 2005 03:56 AM
Pioneer SA-8800 Lorne Solid State 13 21st June 2004 08:56 PM
