I recently picked up an Adcom GFA555-II at a local yard sale in excellent physical condition, but only the right channel works correctly. I checked the fuses, and all are good and the correct rating for the channel rails at 7 amps. It does not blow any fuses on power up or during use and seems to have correct rail voltage +80v/-80v.
I do get a minimal and distorted signal from the left channel with the volume on my preamp turned way up beyond normal listening levels. The only damaged (burned out) component I found was a resistor (R-107) 3.9k on the input board which I replaced…no left channel improvement. Everything inside looks original, all Toshiba labeled outputs. The bias on the right channel is 10.5mV and stable; there is no reading on the left channel. Where do I start looking for the problem? Thanks all—I really appreciate your helping me to get this fixed. Service manual link---http://akdatabase.org/AKview/albums/...%20Service.pdf
"Don't argue with stupid people. You will only sink to their level and they will beat you with experience." |
| Adcom GFA-545 II Schematic Needed | 1moreamp | Solid State | 4 | 18th September 2012 03:11 AM |
| adcom gfa555 | sda2mike | Solid State | 8 | 23rd May 2012 10:03 PM |
| adcom gfa555 | scottr923 | Swap Meet | 0 | 25th April 2011 09:26 PM |
| Adcom gfa555 upgrade | pi industriale | Pass Labs | 0 | 17th August 2010 11:34 AM |
| adcom gfa555 question | rtate | Solid State | 2 | 21st April 2009 09:57 PM |
