Little GEM
Little GEM
Old 23rd October 2012, 04:13 PM   #21
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by AndrewT View Post
what is the difference between loop gain and open loop gain?
What do the .op statements look like for the three conditions you are examining, closed loop gain, loop gain and open loop gain?
Is loop gain the 1/NFB ratio = beta?
Loop Gain(LG) is difference between Open Loop Gain(OLG) and Close Loop Gain(CLG), means OLG-CLG=LG. LG is effective Negative Feed Back at different frequences.
You can't use .op (compute the DC operating point treating capacitance as open circuits and inductance as short circuits) to simulate LG, CLG or OLG, you use .ac for that.
Old 24th October 2012, 10:22 AM   #22
dadod's Avatar
No comments or suggestions on PCB layou???
Old 24th October 2012, 12:20 PM   #23
wahab is offline wahab  Algeria
No , but about the schematic itself or rather the sims,
how did you compute the gain/phase response.?...
Old 24th October 2012, 12:35 PM   #24
dadod's Avatar
I hopped for layout comment, as layout discussion in other thread was quite interesting and I tried to follow suggested improvements.
Do you mean LG or CLG?
For LG I do with TMC resistor init and out of Midlebrook probe. Look at attached diagrams.
dado
Old 24th October 2012, 02:05 PM   #25
It was about the CL phase and gain responses.
Anyway to check stability you can use a square signal
and parralel a 10nF to 100nF cap with the load , it is often
quite revealing.
Old 24th October 2012, 02:31 PM   #26
dadod's Avatar
quite revealing.
I am not sure I understand what you want to know about CLG. How I did the CLG simlation?
I don't have working prototype yet to do Square wave test(I did it on similar standard TMC circuit in my other thread).
Old 24th October 2012, 03:35 PM   #27
Your TMC resistor has quite low value and this generaly reduce considerably
the phase margin once the output is capacitively loaded.
As for square wave test i was speaking in simulation , not in real life ,
as the simulator provide a good estimation of an amp behaviour in this matter.
Old 24th October 2012, 04:29 PM   #28
dadod's Avatar
OK it is here square 10kHz, no cap, 10n//8R, 100n//8R, 1u//8R and 2.2u//8R
dado
Old 24th October 2012, 05:39 PM   #29
Can you post the actual spice .asc for each of the tests, clg, olg, lg with the appropriate .ac activated so that we can see the differences? and run these if we want to duplicate your results.
If you add a .txt or a add .zip to the xxxxxxxxx.asc file name, the Forum allows these to be attached. Or replace the .asc with either .zip or .txt
regards Andrew T.
Old 24th October 2012, 06:04 PM   #30
dadod's Avatar
Here is zip file containig .asc file and models files. Unzip it in the same directory and just run simulation.
There are .tran .ac defined but just one active (.tran or .ac) and others passive(;tran ;ac)
Input generator V4 could be changed from sinus to square just copying the lines already there:
SINE(0 {sqrt(.75)} {freq})
or
PULSE(.5 -.5 0 10ns 10ns .05ms .1ms 8)
there one .ac for (for CLG or LG)
;ac dec 1k 1 1G
and two .tran square and sinus
.tran .4ms
;tran 0 {simtime} {dlytime} {timestep}
dado
Little GEMHide this!Advertise here!
The GEM amplifier hajame Solid State 10 25th June 2013 03:32 PM
little gem mk11 Walcen Chip Amps 4 31st August 2012 01:03 AM
Genesis Media Labs Gem bickeler Full Range 0 7th March 2008 05:25 PM
200w Gem serosmaness Solid State 0 30th July 2006 03:39 AM
Little Gem , Little Gem MkII or the Ruby ? fortuosity Solid State 0 17th November 2005 04:11 PM
Copyright ©1999-2017 diyAudio
