Old 19th October 2012, 05:06 PM   #1
Default ~100khz sinudodial signal superimposed on the output of a common emitter stage
No waveforms as I was too tired last night to grab a screenshot, but basically I have a common emitter stage with a gain of 10, (RC = 10k, RE = 1k) on a diy pcb I made (along with other components such as active crossovers etc). The input is fine (no superimposed sinusodial) but the output at the collector has a small (about 50mV) sinusodial on the output. The gain looks fine (Vout/Vin) ~= 10 and it tracks when I adjust the input trimpot. The output is unloaded (I have not soldered on the output stage yet)
What could the possible reasons be? I swear I have seen this before and corrected it but can't remember what it was.
Old 19th October 2012, 05:16 PM   #2
firechief's Avatar
Could be RF being imposed on the waveform. Try spaning way out wtih the scope and adjust so you can estimate or measure the frequency of the offending signal. Also try turning things off around the work area like floresent lights and wi-fi devices ect.
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 19th October 2012, 05:25 PM   #3
As stated in the title its about 100k (more precisely about 110k). I'll try turning stuff off and see if that help but lets brainstorm for now since I'm currently at work.
I'm going to build this stage on a breadboard and see if this signal still persist. What would that eliminate if it's gone? The power supply?
In what other cases could this happen?
Old 19th October 2012, 07:41 PM   #4
Elvee is offline Elvee  Belgium
Elvee's Avatar
You will first need to post a complete and accurate schematic of the circuit and its surroundings, it is impossible to guess exactly what's going on otherwise.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 19th October 2012, 07:49 PM   #5
Yikes... That is not going to happen until I get home.
One note is that there are 4 opamps (2 8 pin dip packages) on board and every input and output of each opamp is clean, along with the input of the bjt. So is there was an RF or power supply issues it should show up elsewhere.
I must just have something connected wrong in the circuit.
Old 19th October 2012, 09:54 PM   #6
Also, DC voltages are fine, just sinusoid riding on top of it.
Old 20th October 2012, 12:40 AM   #7
Ok, figured it out, for some reason my negative rail has ~120khz noise on it about 400mVpp. Investigating now.
Old 20th October 2012, 12:50 AM   #8
kevinkr's Avatar
LM337 regulator?
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 20th October 2012, 12:57 AM   #9
Originally Posted by kevinkr View Post
LM337 regulator?
nte967
Unloaded there is no ripple. Not capacitor ripple because the noise is 120k and not 120hz. I think it has something to do with the diodes.
Old 20th October 2012, 01:11 AM   #10
Ok I needed to add a cap at the output of the diode string. Strange, not sure why.
Emitter resistor at output stage transistor. smithomo Solid State 33 30th January 2013 01:18 PM
Is a Fuzz Face a common-emitter or common-collector circuit? ninopelo29 Instruments and Amps 6 9th December 2011 01:38 AM
Do we always need an emitter follower to drive a LATFET output stage??? Leolabs Solid State 37 9th January 2011 04:16 PM
Class (A)B output stage: why 2 emitter resistors, why not 1? deleveld Solid State 23 13th December 2006 06:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
