Appreciate some advice on this one.
I use a pair of active (not powered passives), two-way speakers for listening to music. They're great in almost every respect but there is a slight hum I'd like to remove from each speaker. The hum is just about noticeable at the listening position when environment is very quite with no music playing. Obviously, playing music masks the hum. Hum is constant and independent both of speaker's volume settings and whether input connections have or have not been made. The hum doesn't change noticeably at different times of the day either. The hum comes only from each bass/mid driver, not from the tweeters. This baffles me because, being an active design, the amps are directly connected to each drive unit. If the hum is mains related caused by the power supply, why can't I hear it through the tweeters too? Hum sounds like a 100Hz type mains related hum but I'm no expert and could be wrong. Could anyone advise on a generic fix for this sort of hum problem? |
#2 |
thats why you can't hear it in the tweeters
is this a finnished product? or DIY?
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#3 |
Could be a grounding loop.
Or could be the amp just wasnt designed quite right and they have some ripple.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#4 | |
Thanks for your replies.
I purchased the speakers, they're a commercial product. Quote:
#5 |
DC and AC is two different worlds
#6 |
The hum level in each amplifier could easily be the same, simply the tweeter can't reproduce it whilst the bass unit can easily. What are the speakers ? * rgds, sreten. * If its a real problem the internet is your friend.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#7 |
sounds like power supply hum. could be the amps are run from a single ended supply, and such amps usually have a little bit of power supply ripple in the output
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: spammers must die |
#8 |
If you disconnect the input (or better still, short the input ) does the hum go away? If it does, then you have a ground loop. If it dosnt the problem is in the speakers.
#9 | |
If you paid for something up-market or purporting to be hi-fi quality, you could expect better than that but a fix will depend on what's (not) inside. A schematic is needed (unlikely to get outside the service agent's control) or good pics of the works, including top and bottom side of the PCB. Then a fair bit of work and parts will be necessary if the problem is more than just poor location of the signal leads and boards. The problem could lie also in design issues like poor PCB layout, power supply, or insufficient filtering which can be major work to fix. Generic fix?...Not without knowing specifically what you have there and whether modifications would be an economical proposition. As other posts have suggested, the tweeter is filtered, by the definition of an active filtered loudspeaker, to exclude bass - why ever would you expect anything but a tiny amount of high residual harmonics to be heard through them? That has little to do with the tweeter's ability to reproduce bass, as you witness stabbing a bit of DC into one.
regards |
#10 | |||
Thanks to everyone for replying.
http://www.studiospares.com/studio-monitors/studiospares-seiwin-powered-monitors-pair/invt/248030/ Trouble is, their audio quality is so good that I’d like to improve them further by removing that small amount of hum. These speakers rival my main active system in some aspects of audio quality – they’re a bit special and by far the best value purchase of hifi/audio reproduction equipment I’ve ever made. Quote:
Maybe I’m missing something here? This is the way I (currently) understand it – if the hum is caused by an imperfect power supply then this feeds both amps that connect directly to their respective drive units. The audio signal passes through the active crossover before the amps so has no bearing on this. Quote:
I take all points made about possible causes of the hum. I’m willing to chance that it’s caused by ripple from the power supply. If we assume that is the case, what could cause this and is there any way of improving the supply by adding additional components or replacing something? I appreciate specific advice cannot be given but any general direction much appreciated. Incidentally, there is none of the switch on & off thump that I've experienced with other single ended power supply amps but maybe some switch on delay circuitry is incorporated?
| IMPOSSIBLE TO REMOVE HUM IN PHONO PREAMP | ALPUY | Analogue Source | 11 | 6th June 2012 05:34 PM |
| active hum cancellation. PCB idea? | Alexontherocks | Tubes / Valves | 7 | 11th March 2012 06:09 AM |
| Interesting Hum Problem - Active 2-Way | vdi_nenna | Pass Labs | 44 | 14th August 2011 09:54 AM |
| Hum in right speaker becomes hum in both speakers when headshell detached | THX1979 | Analogue Source | 16 | 24th June 2011 08:59 AM |
| How to remove hum sound? | Kimhua | Solid State | 7 | 5th July 2003 03:56 PM |
