Creek 4330 died - Page 2 - diyAudio
Old 26th February 2013, 10:31 PM   #11
I got a response from Luke Creek, very nice of them...
"The HUF76339 device is a suitable replacement for the BUK555" I think thats a typo. its the HUF75639.
in case anyone was wondering. I also found R20/R120 toasted, still waiting on parts. He also sent me the 4330v2 schematic.
wig
Old 27th February 2013, 04:57 AM   #12
Ulis is offline Ulis  Russian Federation
You can use IRL540.
Old 27th February 2013, 05:16 AM   #13
IRL540 - Logic Level - You can use
IRF540 - You can not use
Old 27th February 2013, 09:28 AM   #14
Generally, for audio, you don't want low Rds(on) which is characteristic of most newer developments in switching devices, but high Rds as in the BUK555 are better from an audio distortion POV.
HUF75639 will certainly work but make sure it is the right P3 suffix type for a T0220 style package or it will be something else. I suspect it might not be ideal due to low Rds.
IRL540 NPBF looks closer and is available widely, from Newark at least in the US. Note that max. current rating is only ~30% of the BUK555-100.
Ian
Old 27th February 2013, 12:00 PM   #15
Alex Nikitin, is the developer of the amplifier CREEK 4330.Instead of HUF-s he recommends IRL540.IRL540N little worse.I cloned the amplifier using IRL540
Old 27th February 2013, 06:12 PM   #16
Here's what I have coming, thanks for all the inputs.
512-HUF75639P3
MFG Part No:HUF75639P3
Fairchild MOSFET
wig
Old 27th February 2013, 06:16 PM   #17
diyAudio Moderator Emeritus
jean-paul's Avatar
Hi I think I have a small rail with BUK555 devices. Will check if you still need them.
It's only audio. Member of the non modular PCB design committee
Old 27th February 2013, 07:28 PM   #18
and check with "x-pro" here, Nikita, he probably designed it.
Old 14th March 2013, 06:53 PM   #19
Amp is back in service, I used IRL540 from mouser. Found zd3 was dead and r20/r120 out of spec. Thanks for the help. If anyone needs the 4330r schematic let me know and I can email it. The bias setting for this one is 3.5mV, thx again.
wig
Creek 4330 Mkll. Mint condition. tweakk Swap Meet 2 6th March 2011 07:07 PM
Creek 4330 PCB totalmass Solid State 1 25th June 2008 01:39 AM
Creek 4330 5u4 Swap Meet 0 30th May 2008 06:46 PM
Creek 4330 ...curious power inside redrabbit Solid State 3 26th December 2007 06:11 PM
Creek 4330 5u4 Swap Meet 0 12th November 2007 05:50 PM
Copyright 1999-2017 diyAudio
