Dx Blame ST together Dx Super A - Page 82 - diyAudio
Old 5th June 2013, 02:04 PM   #811
I add you on facebook , please accept me Greetings
Old 8th June 2013, 09:15 AM   #812
krojo is offline krojo  Poland
Can I use C4468 and A1695 ?
Old 10th June 2013, 10:58 AM   #813
destroyer X's Avatar
Default These transistors are not that huge
They are very good....but the power dissipation derated is not that good..also the maximum continuous current is not that big too..
It can be used, sound will be excellent, no doubts, but you will not be able to connect 2 ohms loads anyway neither 4 ohms speakers that have valleys of impedance lower than 4 ohms (almost all them have these lower impedance frequencies...so...all them are very dangerous)
So..... not completely or entirelly guaranteed at 4 ohms.... where power is 150 watts RMS each channel... some care will be needed.... not to push it too much hard for too much long time.
Better is not to use 42 volts....better to go down to 40, or 38 volts or even 36 volts aproximately....or to install another pair in the output.
You see this is because of 70 degrées centigrades..the worst case scenario of bad heatsinks, bad flan blower and bad installation inside the enclosure with bad vent holes and all bad stuff joining together to produce a big trouble.
Of course, to operate 8 ohms it is very safe and the power amplifier can reach, easy, 80 watts RMS with low distortion when feeded by 42 volts supplies.
30 plus 30 volts alternated and 550 to 600 watts or 600 VA transformer will be good to feed two channels of these amplifier to operate 4 ohms full rated power.
Good luck!
regards,
Carlos
Old 11th June 2013, 11:53 AM   #814
post813 shows the de-rating and how to determine a maximum operating dissipation for driving a resistor load.
Driving a speaker, that is a reactive load, is very much more stressful.
A 2pair output stage using 100W devices can do 150W into 4r0 resistor, but it will not be reliable working at near maximum powers into a 4ohms speaker, if the devices get hot.
The de-rating for a reactive load can be either using 8ohms speaker, or domestic listening into a 4ohms speaker, where the average power output is ~20dB below max power.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th June 2013, 10:49 PM   #815
Project16's Avatar
Hello Carlos!
I finally met all the elements of my amp and assembly has begun.
The heat sinks, the Sanken and two transformers were stored for over twenty years and are now used to this amp.
Here are some pictures from the beginning and as soon as I finished all the amp I am sending others.
Thank you for this achievement!
Old 15th June 2013, 09:47 AM   #816
Default Very nice.... thanks a lot by the pictures
It is looking great!
regards,
Carlos
Old 15th June 2013, 02:33 PM   #817
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
oh jo joy !!!!! looking good mister Project16 surely looks really good, Sanken classic
Vargas
Old 15th June 2013, 03:54 PM   #818
Default I have just received my kits of parts and pcboards
To assemble a stereo Dx Super A (Brazilian white pcboard) and a Dx Supply.
regards,
Carlos
Old 15th June 2013, 04:16 PM   #819
Default Boards and parts arrived to build a Dx Super A
Here you have some pictures.
We are NOT offering to the international community due to the lack of confidence we have related Brazilian Postal System...in other words..we cannot guarantee the package will arrive your place...if you want to take the risk by yourself..then go to Zimmer:
imap.eletro@gmail.com
regards,
Carlos
Old 15th June 2013, 05:09 PM   #820
Default Brazilian group buy pcboards arrived at my home
Here you have them:
Placas para Dx Super A chegaram - YouTube
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 02:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 01:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 10:26 AM
Copyright ©1999-2017 diyAudio
