Dx Blame ST together Dx Super A - Page 73 - diyAudio
Old 26th March 2013, 07:22 AM   #721
destroyer X's Avatar
Default A small error remain in the pcboard layout... was not fixed by Juan
Zimmer informed the error remain there.
Please, do not assemble the last pcboard published in thread above till i post the fixed layout.
The schematic shows two output pair, in the reality we are using three, this is a matter to include on more only.
Soon we gonna have this fixed.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 26th March 2013, 07:33 PM   #722
Default We are fixing the layout and also making an upgrade into the Dx Supply
It was made to be used together the Dx Super A.... good to feed two channels pumping full power... reason why i have changed something in the schematic..include more capacitors and one transistor more.
Resistor of 0.000001 is the resistance of the cable.... do not worry...it is nothing.
Coils are two layers, each layer may have 12 to 15 turns, wire is 0.5 to 1 milimeter diameter... total turns from 24 to 30 turns... resistor will be the core, as 3.3 ohms resistor, a 5 watts unit.
regards,
Carlos
Old 27th March 2013, 01:17 PM   #723
Default We are working into the Dx Supply layout..nobody sleeping here
Working hard...without stop.
Juan is increasing high current tracks width.
Here you have also an example of connections...observe fuses...each one of them must be calculated based into your parameters....if you are novice and wants some help.... a beginner...then come to uncle charlie and i gonna give you, gladly, a helping hand.
carlos.eugenio1951@yahoo.com
regards,
Carlos
Old 28th March 2013, 08:36 AM   #724
regards,
Carlos
post723,
the switch must go in the same Live feed as the fuse.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th March 2013, 10:00 PM   #725
Default Here you have updated files about the Dx Supply
It is appointed to be used together the Dx Super A.... in a matter of fact, any series pass regulator will fit..the ones have error amplifier.
This one was hardly tested since they where published by Ampex in 1973...i have modified a little but it remains almost the same circuit.
Enjoy and be happy...here you have updated files about it.
Please, do not build before you have read all Dx Supply thread...if you need some help, then email me your parameters and i will give you some help about... Dx Supply thread is here
Dx Supply, output adjustable, stabilized power supply
read it from the first to the last post to know the evolution and all details you must know to decide what to do further.
regards,
Carlos
Old 29th March 2013, 05:37 AM   #726
Default Sorry folks, but remain error in pcboard
Juan made a mistake again
Because of that he will assemble the next fixed circuit at home in advance to publish images or send em to me.
I am sorry.
Do not assemble the last posted images because has serious errors.
regards,
Carlos
Old 29th March 2013, 10:21 AM   #727
Qmara is offline Qmara  Indonesia
I am sorry.
regards,
Carlos
thank you for your information uncle charlie, but which one of the last posted image were mistake, i mean from what page / post.
Old 29th March 2013, 01:15 PM   #728
Default No image is good...first because we made update... we have made a new
and better, and stronger supply.... all images posted after that...with the new supply, had mistakes.
So, you can trust in the last schematic posted (green and yellow frame surrounding it) but you should not trust in any layout published.
This forum does not allow us to delete posted images...better would be if we could delete the wrong ones..but i cannot..so..they are still there, posted and wrong.
Do not assemble based in ANY layout made to the Dx Supply.
One that i have made by hand you can trust..but that one is the first model that is too much weak and cannot face the drain of current of two channels operating full power at 2 ohms loads.
Answer is "no one!".... no layout is really fine.
Wait the Zimmer layout or Juan Vargas layout tested with photograph of prototype assembled and tested shown as certificate and guarantee of quality and reliability.
regards
Carlos
Old 29th March 2013, 01:50 PM   #729
Default Here you have the schematic
If you can, then make your own layout or wait our future fixed (real fixed) layout that gonna be posted together picture to show you it was tested.
regards,
Carlos
File Type: jpg Dx Supply, parts modified, update march, 29.jpg (356.7 KB, 105 views)
Old 30th March 2013, 01:01 PM   #730
Default Here you have updated schematic
Was revised today.
Do not worry about sufix AG.... the numbers are correct, also the prefix.
regards,
Carlos
File Type: jpg Dx Super A - revision march, 30, 2013.jpg (669.7 KB, 137 views)
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 02:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 01:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 10:26 AM
Copyright ©1999-2017 diyAudio
