Dx Blame ST together Dx Super A - Page 50 - diyAudio
Old 26th January 2013, 03:12 PM   #491
destroyer X's Avatar
Default I have made some torture tests, and i understood it is better to increase
Miller capacitor value...trying a different transistor (Video) i found this need.
So, here is the suggestion, increase it to be in the safe side.
Dx Super A update and more - YouTube
regards,
Carlos
Germans!.... watch this!:
https://www.youtube.com/watch?v=S63ecXwslas
Old 30th January 2013, 11:04 AM   #492
Default Zimmer, from Brazil, will produce pcboards to supply internally in our country
But he can also provide you boards if you need.
Now a days we are testing.... he will assemble to test using scope to watch if something in the pcboard is creating problems...square wave, triangle and sinusoidal in several frequencies and levels will be tested.
Then he will order first batch of 100 boards to provide Brazilians that have already reserved.
We decide to provide the option to T03 because our rednecks have not sophisticated transistors in their towns...they have to order into the WEB and people here do prefere to go to their shops and buy from someone...our tradition is this way...and people want 2N3055 and 2N2955, so, i have prepared a pcboard in order for them to use these transistors into 8 ohms and with some reserves to use at 4 ohms (in this case i have suggested some modifications).
Also people here wants TIP35/36, because they are the second most popular transistors in Brazil, used in hundreds of automobile amplifier models.
So, we will provide these three options in a single board.
This idea came from Brazilians asking that and also Joseph Siejack (Evette) from Canadá.
Zimmer do not know the price as he have not ordered yet..he will test the board prior to order.
Here you have his email...so..if you want something, go directly and straigth to him because i do not sell anything and i do not touch in money...my stuff is to enjoy audio, to create, to test and to share...money i have from other sources.
Zimmer lives in a farm, his daddy and grandfather works in that farm, they came from Germany and Zimmer works for an Electrical Company, married, several sons and a very good man... religious and serious man.
imap.eletro@gmail.com
regards,
Carlos
Old 30th January 2013, 12:16 PM   #493
Default BOM for Zimmer's pcb
Hi Carlos,
Will Zimmer's board accept the same BOM as Juan's? I mean regarding the physical size of components.
Cheers
Old 30th January 2013, 01:53 PM   #494
Default I am not sure Junior.... i will ask him to prepare
Maybe yes, maybe not.
regards,
Carlos
Old 30th January 2013, 09:11 PM   #495
Default I have asked Zimmer, he will prepare the BOM
Then you gonna have it..... wait a couple of days and write to him, he may share black and white layout and BOM.
The gerbers he was instructed not to share because pirates are terrible now a days in Brasil, they are searching for good amplifier and they are copying to sell in Brazilian free market (E Bay)..so, we are not publishing gerbers anymore the way we used to do because of that.... not publishing and not sending to people as we never know if the one we are in contact is a pirate or not... we cannot know people decense while in internet..this depends on long knowledge and close non virtual contact.
regards,
Carlos
Old 30th January 2013, 09:15 PM   #496
Thank you Carlos.
Junior
Old 31st January 2013, 12:22 PM   #497
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Hello guys !
Happy to inform that mister Joshvi got his boards I inform him to take his time there is no rush to put it together, for me take 3 days because I double triple check all the components, so I let him know about that "we humans we make mistakes from time to time". is our nature
Juan
Old 31st January 2013, 07:26 PM   #498
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Originally Posted by destroyer X View Post
Compared to the Dx Blame St i have made modifications...the inclusion of a 1K resistor in series with the first VAS colector, the gain resistor now is 1200 ohms, the input resistor that sets the input impedance is 56K and this will allow you to use 680n capacitors to the input.... maximum is 1uf in the input and please try units with small insulating voltage..do not use big ones to 250 volts or more...better to use 6 volts of insulating voltage there...or even less..capture electrolitic condenser from a junk... small cassete players, small radios.... these ones have small insulating voltage condenser and capacitors due to their supply voltage that is low.
regards,
Carlos
Hello Ancle Charlie,
Is it ok to use this electrolytic capacitor for the input as per above recomendation? if it is possible what would be the polarity direction?
Old 31st January 2013, 10:29 PM   #499
Default Some studies were made, dear Bahrain, that have shown to me
We should not use high voltage insulating voltage to electrolitic condensers in places the voltage is too much small.
I strongly suggest you to search for some junk, walkman or any kind of portable devide that operates with low voltage (batteries) and then you should pick up the small capacitor to your input.
Electrolitic suffers from heat, as the electrolitic material can be lost when operating in overheated areas...then we gonna have bad results....but.... capacitors used in low voltage, low power and low heat appliances, may be like brand new ones.
Also you can use non polarized capacitors to the input.
Voltage there is too much small.... not a good idea to use 50V condensers there
I have not at hand the paper that explains the troubles this produces...better to be in the safe side and select small, low voltage units.
You can even supress this capacitor, substituting, or replacing it with a piece of wire, if you are sure your audio source has no DC (measure and be sure about that before you plug into an audio power amplifier that has no capacitor in the input)...this brings some advantage to you... each supressed passive part is an advantage.... sound becomes more and more clear.... there are some parts we can do that... sadly they are not that much.
Automobile radio units, or automobile CD players...all these ones have nice 16 volts condensers inside..... it will be a little bit better option than 50 volts unit
I will reach the paper, then i will be able to send/publish to the ones have interest.
Each small part plays a roll in the final audio quality, we must take care about some details, and this one, at the input, it is critical.... because it is the only capacitor coupling we have in whole audio power amplifier...we have decoupling..but coupling only this one.
Non polarized we have several types..use the one you want... people say some of them distorts, i really do not know about that to suggest you some kind of material...i do like ceramic..but 1uf may be a little bit big and hard to find with small insulating voltage.
I understand this looks foolish, unobtanium and big magic....but better to be in the safe side... people that knows more than i know (more practice is valuable) say this is important...i do not discuss because each day we learn something more...i really could not listen the difference..but i do not discuss, because if this cannot really make the difference, at least will not harm sonics too.
regards,
Carlos
Old 31st January 2013, 11:00 PM   #500
wiljj78's Avatar
Default Thank you Uncle Charlie
It is more clear for me now the role of this capacitor as i could not find this one in the market even to salvage from the scrap pc board, and i doubt to use this electrolytic cap on my stocks as it may not able to contribure the right/preferred function on the circuit, but as you said non polarize cap will also do the job so i'll try to search this one tommorow.
Many thanks....
Wiljj78
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 06:34 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 03:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 02:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 11:26 AM
Copyright ©1999-2017 diyAudio
