Dx Blame ST together Dx Super A - Page 31 - diyAudio
Old 3rd December 2012, 10:12 AM   #301
destroyer X's Avatar
Default Here you have the adjustment setup
You may have this protective series resistor on board, or maybe not...we are still thinking about it, as people may burn the fiberglass with some kind of misadjustment or errors into the circuit board assembly... fuse socket is to be installed on board..but resistor may be outside, in between the supply pcboard and the power amplifier pcboard.... installed to adjust and them removed.
Image attached,
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 3rd December 2012, 10:59 AM   #302
Default This resistor watt rate is an overkill
2.5 volts over 10 ohms, means 250mA and this result in 625mW
But 5.0 volts means 500mA and this result in 2.5W
If people try 700mA, then the voltage drop will b 7 volts... results in 5W
But if people make mistakes into the amplifier constrution, shorts and things alike, misadjustment into the bias trimpot..them the current can be several amperes and even the 10 watts resistor will smoke.
This watt ratio will be good to the tweakers...for sure they gonna try 1 Ampere, they will regret and will return to 0.25A
The VBE multiplier working as heat sensor is unable to compensate when the heatsink is too much hot.... so.... with huge dissipation of 60 watts each rail or more, the heatsink will be so hot the transistor will not be able to reduce in the ammount we need....this way...or you use small current or you install dual super fan blowers and giant heatsink and install this devil machine (hot) over a block of Ice in Siberia or Sweden.
Big mistakes will smoke protective resistors anyway...well....they are there for this reason.... to avoid excessive current into the circuit board and to burn opening the circuit alike a fusistor.
regards,
Carlos
Old 3rd December 2012, 02:10 PM   #303
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Here is the last image of the board the update was made last night at midnight "local time in Puerto Rico" I send the new files to the engineers so a they can begin the order.
Juan
Old 3rd December 2012, 04:32 PM   #304
Default A much more realistic image from Juan Vargas
Thank you Juan.
Why the left multimeter black cable is cutted?
jejejeje!...means ahahahahah! in spanish.
regards,
Carlos
Old 3rd December 2012, 04:38 PM   #305
Default Your left multimeter will not read...because no black cable
The one at post 304 is defective.
OhohohohohŰh!
regards,
Carlos
Old 3rd December 2012, 05:04 PM   #306
hahahahahahahahahahah que loco !!!
Juan
Old 3rd December 2012, 05:40 PM   #307
Default Mucho loco gracias a Dios!... very crazy thanks God
If i was not crazy, how could i tollerate some guys we have around in our forum (10 guys)
If i was not crazy i would not take all my free time to create, develop, build, design, test and torture amplifiers.
If i was not crazy no way to help layout designers to follow "Corporation" rules.
If i was not crazy no tenths of amplifier produced for free.
If not crazy 1000 guys would not have the pleasure to make their own audio power amplifier... with their own hands...in their own house.
Thanks God uncle charlie is idiot, and crazy!
regards,
Carlos
Old 3rd December 2012, 06:49 PM   #308
Bigun is offline Bigun  Canada
Bigun's Avatar
Crazy? very likely
Idiot? I don't think so :-)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 3rd December 2012, 08:42 PM   #309
Default Thank you Bigun...you are a friend... reason why you use to give
me some "discount" in your evaluations.
This is the final comment about the Dx Super A.... adjustment and how the circuit goes operating...thermal issues, thermal drift, what we can do..what we cannot do.
I hope you enjoy
Dx Super A adjustment - YouTube
Please subscribe to Carlos Mergulh„o in the Youtube..this helps me to attract more guys to build my amplifiers..the more subscribers the more guys comes to see my videos...please click into like, the fingers up image...and leave a comment if you want.
Sorry, i have heard and i could see my english is not good....but it is the best i can do.
regards,
Carlos
Old 3rd December 2012, 08:57 PM   #310
Default Humans are lovely
Creativity and ingenuity... these thingas applied to audio electronics will bring wonders to our lives.
regards,
Carlos
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 02:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 01:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 10:26 AM
Copyright ©1999-2017 diyAudio
