Dx Blame ST together Dx Super A - Page 21 - diyAudio
Old 17th November 2012, 04:09 PM   #201
destroyer X's Avatar
Default Here you have the entire schematic.
regards,
Carlos
Germans!.... watch this!:
https://www.youtube.com/watch?v=S63ecXwslas
Old 17th November 2012, 05:55 PM   #202
Default Juan will produce pcboard to the Dx Supply
What you can see that may look strange?
First you gonna see a 3300uf in parallel with 220uf.... this looks crazy, but it is not...the big one is to use together Class A amplifiers or Super A amplifiers, the other is to Class AB amplifiers...into the board you will solder one or other, or will short jumpers to switch from one condenser to the other.
You can see diodes...the left ones are connected to the supply, a non regulated supply, so, having voltage drop you gonna see variations into the LED light intensity.
Also you can see green LEDs in the output... this is the regulated, or stabilized side... there you should have small voltage variation and the green LED should light in a steady way without too much flicking.
regards,
Carlos
Old 17th November 2012, 07:37 PM   #203
lineup is offline lineup  Sweden
lineup's Avatar
destroyer X
I see the DX corporation can not offer a Headphone Amplifier.
Why?
So many amplifiers but not for Headphones.
You have no headphones, Carlos??????
Okay.
I will put my fingers onto my drawing board.
Then I will make you a schematic over THE BEST Headphone amplfier.
Because anything what corporation will offer is always the best.
First was DX Amp best. Then.. Then ... And now the Super A is THE BEST.
Now we make the best headphones amplifier for the people?
Wait Carlos and I send you schematic of Headphone amplifier.
If you like it, you can have it.
And publish here a great Headphone amplifier.
And say thanks to Lineup.
Lineup
lineup
Old 17th November 2012, 09:20 PM   #204
Default I really do not have a good headphone...also i live alone
dear Lineup as you know..... i have not the need to use them at home not to disturb people around.... there's no people around most of the time.
But for sure a headphone is a much better tool than power amplifiers together speakers because troubles with acoustics.
The first amplifier i have created (try and error and basic knowledge about how to calculate a single transistorized stage) was a headphone amplifier...was maybe the 500th unit build...several power amplifiers resulted busted in my workbench due to design errors from the Magazine publishers, enginners, and revisers of graphics (image) and text....mistakes happened a lot and was very frustrating to me.
This is the main reason i try to help people with basic electronics, practice, some daily skills that i have obtained burning my fingers... then i decided to help people to avoid them to face the domination of the technocrats, when some of them does not want to teach things, keeping to themselves the knowledge as this means power...so... i am not that good... it is also a revenge... not to allow a few guys keeping all know how only for them...i am spreading these basic things whole world...or trying too.
The amplifier i have made was for a Senheiser headphone saved from TV Globo fire that destroyed the television station.... i found it half burned, but protected by some kind of aluminium sheet and i have made a foam to the headphone, was made by a dual 400 ohms microphone cartridge...this was the driver of this headphone...lovely sound!.... then i prepared a one stage circuit, using BC107, a metalic case Philips transistor, a silicon unit (modern for the seventies) and a couple of resistors, a 9 volts battery and then i plugged into my Akai 4000DS MKII open reel recorder and i have perceive the pure sound for the first time of my life...and i understood that all amplifier together speakers had not that performance.
I am trying, since these days, to have the same sound at my home with speakers and amplifiers...i do think i have succeeded since the Dx Blame ST, but i do respect a lot headphone amplifiers.
There'a some lack of motivation, as i have no headphones to use together a very high end headphone amplifier alike yours.... i do build things for others, things i dislike alike Class A (too much hot, low efficiency) but at least i have to test, and i can listen to it.
Headphone amplifiers i will not be able to listen, as i have none...and the ones i can find in Brazil are so poor that does not deserve attention...most of them are chinese.
Thank you anyway... this one i will not even listen too...so...it is too much sacrifice to my old heart to make something that i cannot even test.
regards,
Carlos
Old 18th November 2012, 07:43 PM   #205
Default Buikd this amplifier folks...give yourself the opportunity to feel Dxcellence
Nothing could be more pure than the purity.
This amplifier give you the most perfect sound... the original sound from the recording... excellence in audio amplifier ... this is mine best unit.
Much more than perfect..it is the perfection itself.
Dxcellence.
regards,
Carlos
Old 19th November 2012, 07:17 AM   #206
Default Gentlemen, this one is transparent... there's no colouration
In the sound reproduction, it is clear into the highs, perfect into the mid ranges and precise into the bass.
Does not include harmonics, the opposite, it is filtering the annoying third harmonic that we call the "transistor sound"...and has some ammount (needed) of second harmonic, the "tube alike sound".
It is perfect...anything can be better than perfect.... what this means?
You can build or buy something that has the same performance...but never will buy or build something better..because there's no room to be better..it is already in the dead end..the top end..the maximum level of purity....distortion is very small, almost unbeatable...it is less than 0.00013% THD to full power....yes....i said full power!
It is flat, there's no gain anywhere...so...the sound is amplified in the wire with gain style.
Dinamics is perfect.
Sound reproduction is perfect.
Bass is perfect
Mids are perfect
treble is perfect
Input impedance is perfect
Audio transference to the speaker is perfect
And it has a miraculous feature... and do not ask me how i got that because i do not know...was an accident...it plays great sound with ANY cheap speaker... this is miracle, that nice conversation with the speakers, this interaction, it is really a miracle (because all we do not understand we call miracle)
You may say:
- "You told that before uncle charlie... how can i believe now?!
Dx Blame ST was the best wide world ever made amplifier...TILL another one was made..then the ever made was supressed from the sentence automatically..got it?
Can i make it better....maybe dinamics...maybe some sound signature...maybe i can polute the harmonic distribution a little...maybe i can increase power, or decrease...i can put some leds flashing on it...i can put perfum or golden capacitors...but sound cannot be better than the perfection.
This is perfect... for free to you... can beat whatever you put into comparison.... will eat all amplifiers..including the Dx Blame ST.
Build it...over a wooden board with copper nails and telephone wires if you have not money or parts...make it with other transistors if you have not the good ones...make it with other supply voltages if you have not the good one...make it with small condensers if you have not good ones...make it ugly if you cannot make it pretty....and even this way..will kill, smash, destroy your 20 thousand dollars fashion golden amplifier.
Guaranteed or i will eat my amplifier.... with the AC plugged into the mains!
I am saying...all others are loosers...this is the one!
I challenge you to show me one that has beated....but come with testimony, because some enemies may be interested (competition) to destroy the amplifier only because envy... i want 3 guys sign below a text or a video showing me an amplifier that could beat this one.
No way!..this will never happens... i am absolutelly totally sure this is impossible..only if people produce a hoax to be playing with me.
regards,
Carlos
Old 19th November 2012, 07:36 AM   #207
Default I am so sure about what i am saying that i will ask you to do
something to give you a lot of advantage over my amplifier.
take your amplifier to a speaker shop...then go trying all speakers...select the one matched with your power amplifier.
Now install the Dx Super A, 5 watts output..the same power to your looser amplifier...then play a song.
Use the last schematic published to the Dx Super A, use the Dx Supply, adjust iddle current to 700 mA, switch of, for some seconds, the fan blower and listen.... then you can be silent not to comment this...as you may feel ashamed.
Be aware you must switch one and other.... after a couple of seconds our ears adjust everything and even junk can sound good.... first two seconds you will be able to feel the real thing.
Got it?
Sorry men.
You loose!.... but you also is a winner...now you have a decent amplifier...try to excuse yourself because you have spent so much money into that beated one.... try to sell it.... be silent about what happened and sell it.... say sorry to your wife and give her the money you spent in that sold amplifier...the looser one...this will shut her mouth.
Old 20th November 2012, 11:55 PM   #208
abetir is offline abetir  Philippines
...just noticed in post #189 (pdf files)...
My dear Juan, the pdf for toner transfer hot iron method should look like the attached image... The image in your pdf was the bottom copper view, for toner transfer it should be the top copper image.
File Type: png Dx_SuperA_ mirror_etching_hot_iron_flipped.png (184.3 KB, 456 views)
Old 20th November 2012, 11:59 PM   #209
check this image...thank you!
File Type: png Dx_SuperA_ mirror_etching_hot_iron_flipped.png (184.3 KB, 393 views)
Old 21st November 2012, 03:32 AM   #210
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
but dear abeti why you flip the image? check this out bro both images be happy!
Juan
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 06:34 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 03:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 02:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 11:26 AM
Copyright 1999-2017 diyAudio
