Dx Blame ST together Dx Super A - Page 101 - diyAudio
Old 22nd September 2013, 11:14 PM   #1001
destroyer X's Avatar
Default Dear Terry, your transformer can "produce" 350 watts RMS of sound
So, it will be good to power two channels of the Dx Super A operating at 8 and also 4 ohms.
In the reality your will have to adjust your Dx Supply to 35 volts to keep some volts available to the regulator to do it's job... this way your output power gonna be 50 plus 50 watts RMS at 8 ohms.... 100 plus 100 watts RMS at 4 ohms and will be able to put out 160 plus 160 watts RMS at 2 ohms.
Your heatsink must be bought to dissipate 250 watts each one of them.... i do think in the internet you can buy heatsinks using the watts as data to enter..if not, then ask a forum friend to help you.
I am a Broadcasting Television Professional, and a Psychologist as a degrée (never used...just a paper to decorate wall)...i also do not understand about heatsinks.
I have developed a method.... and this is easy to understand:
A squared blade of aluminum, 4 inches size to each side, 1 to 1.5 milimeters thick, is good to an amplifier putting out 10 watts RMS of audio.
So, 2 blades (fins) will be good to 20 watts
So, 3 blades (fins) will be good to 30 watts
this way you can evaluate the heatsinks you have...based into dimensions.... convert into area multiplying side by side and make your calculations
Each amplifier channel, will need 16 of these blades to continuous power.... a half of that for music...but if you push it hard at 2 ohms...if you gonna use 4 and 8 ohms...these heatsinks you see inside mini audio systems will fit..these ones you see attached to STK audio amplifier modules..count the fins and evaluate...this is all i can do to help you.
No problem to make mistakes...if you decide for a really big heatsink..much bigger than the size you need..the result will be your amplifier operating cool...if you decide for an unit smaller than the needed size, then it gonna be too much hot and you will attach a fan to help the cooling...just that.
regards,
Carlos
Sorry, Brazil only to be sold... top secret ultimate schematic, not to share...encapsulated VAS:
https://www.youtube.com/watch?v=PHnAky2fV1w
Old 23rd September 2013, 02:03 AM   #1002
still4given's Avatar
Another question if you don't mind. I have several 4700uf 50V caps. Will these be OK in PSU board if only using 25-0-25VAC transformer?
Old 23rd September 2013, 02:37 AM   #1003
I can try answer that if Carlos doesn't mind. Just multiply voltage of the transformer x 1.41. This will give the dc rail voltage. 25x1.41=35v dc. I usually choose something 10% or better. So 50v caps are perfect.
Simon
Old 23rd September 2013, 04:45 AM   #1004
Default Thank you dear Simon
I am glad you are here to help.
regards,
Carlos
Old 23rd September 2013, 05:05 PM   #1005
Default Almost half or the whole batch was sold.
I suggest you to move.
Well.... in one month we gonna have white pcboards from Zimmer too..the Brazilian pcboards.... same price.
regards,
Carlos
Old 23rd September 2013, 09:49 PM   #1006
Wow, OK, so I sent payment at 3PM on Saturday and the boards arrived today. Simply amazing. Nice boards too. So much for me gathering the parts while I waited for the boards.
Only one bummer, the PS caps that I was hoping to use don't fit. The caps I have are 35mm and the board needs 25mm. Not a huge deal but there are twelve of them. Looking on ebay right now. I already completed my order from Mouser. That should be here any day.
Thanks Juan for being so prompt!
Blessings, Terry
Old 24th September 2013, 12:05 AM   #1007
Terry see if you can drill new hole for your caps to fit. Usually excess traces on filter cap are adaptable to different size caps...
The stuff you don't know always humbles us.........
Old 24th September 2013, 02:14 AM   #1008
Originally Posted by vargasmongo3435 View Post
Hello guys
well I like to share my ideas as always I was simulating how the final project looks like using Google Sketch
Hi Juan, I really like the way you have mounted both amplifiers (stereo pair) on a single heatsink. I will be building my DX SuperA with single heatsink in the middle of the case seperating the transformer and regulator board.
In my opinion this makes for a "cleaner" looking case (no heatsinks visible on the sides or back of case).
Old 24th September 2013, 03:25 AM   #1009
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Blessings, Terry
I'm happy for you mister Terry you did get the boards fast wow !
Juan
audio fanatic only
Old 24th September 2013, 03:48 AM   #1010
can you make a quick drawing of your idea if possible ?
Juan
audio fanatic only
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 02:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 01:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 10:26 AM
Copyright ©1999-2017 diyAudio
