Dx Blame ST together Dx Super A
Old 9th July 2013, 10:05 PM   #891
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Originally Posted by vargasmongo3435 View Post
0.o_ again ?
Juan
Yess...
Old 9th July 2013, 10:26 PM   #892
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default You can use any 50K or 100K potentiometer you find
wire it with the most short connections you can, a good shielded cable for audio and be happy.
Thank you forgiven, as you gave me the oportunity, together dear Project 16, to open my big mouth.
"Avoid preamplifiers video message to Corporation members":
http://www.youtube.com/watch?v=jLUgKzNzbtA
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 9th July 2013, 10:35 PM   #893
lanchile is offline lanchile  United States
lanchile's Avatar
I agree with you Carlos! I have build some amps with just good pot to adjust volume and they sound so good. I have try using many sources like: dvd, iPod, laptop, pc, mp3 and they played without hiccups. I guess it is in the design and gain of amp and the output of source. People always say the problem with impedance and inductance match. I build the B1 using matched transistors and top quality caps and I did not notice an improvement in the sound at all. What I do is I use the best quality potentiometer like TKD in line and I always try to use the shortest path from input to potentiometer and from potentiometer to amp board. and I use the shortest RCA cables from source to input of amp. This kind of passive integrated amplifiers are very well know. Just to name some: Acurus D100, Portal panache, Adcom, and Creek. but there are many, many more out here. if people do not use phono...go passive!!!
PS: In my M400 amp I use a 10K TKD pot.
Make it simple...Make it better!
Old 9th July 2013, 10:36 PM   #894
Default They will not be happy with uncle charlie....but i have to say what is the real thing
The brotherhood of believers and mystics will get angry dear Vargas.
What i am saying is the same i heard from this man, in 1981, during a dinner.
The man is Akio Morita......do you know the guy?....so...he is not stupid.
Thank you Lanchile..... thank you too.
regards,
Carlos
File Type: jpg Dx in Atsugi Plant, - Sony Corporaton.JPG (439.9 KB, 465 views)
Old 9th July 2013, 10:41 PM   #895
Project16 is offline Project16  France
Project16's Avatar
My tests were done with a double potentiometer 100K between the source and the amplifier and the return is great.
But I read somewhere that it would be better to fit a high impedance to a low impedance (buffer) and add the potentiometer.
Apparently it does nothing!
Regards!
Old 11th July 2013, 10:48 AM   #896
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by AndrewT View Post
Measure the bias voltage (Vre) across the output emitter resistor.
this is how you get the output transistor idle current...
bias voltage to the input or base is measured somewhere else...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 11th July 2013, 05:25 PM   #897
Default Well... i see harmony....this way is better
thank you,
regards,
Carlos
Old 17th July 2013, 08:27 AM   #898
Default I am glad i could reach 62 years old healthy
Dx birthday - YouTube
Thank you all by the friendship, the respect and support.
regards,
Carlos
Old 20th July 2013, 11:25 AM   #899
Project16's Avatar
Default Increase the setting of the quiescent currents!
Hello Carlos!
Currently I have 2.50V on resistance of 10 ohms setting and how my DX is apparently perfect but heat sinks not very hot.
Is it possible to increase this setting and here is what would bring more?
Regards!
Old 20th July 2013, 11:33 AM   #900
measure the output bias at the output device emitter resistor.
Do not try to set up the output bias by lowering the supply voltage by 2.5V
regards Andrew T.
Dx Blame ST together Dx Super AHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 03:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 02:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 11:26 AM
Copyright ©1999-2017 diyAudio
