Dx Blame ST together Dx Super A
Old 6th March 2013, 07:52 PM   #641
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Originally Posted by Rudi_Ratlos View Post
Willjj782, did you isolate the nuts and bolts of the build of the transformers?
If not, then you are introducing an additional secondary transformer winding, painted pink. This is not good!
Best regards - Rudi
On the first time when I install and power them up all together the problem occur and I try to insulate the bolts and nuts vs. the aluminum plate on top in order not to act as a short winding, and later when I found the solution of the root cause, I try to remove the improvise insulation and they all works fine and no problem.
Thanks Rudy
Wiljj78
Old 6th March 2013, 07:54 PM   #642
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Very good observation Rudi...thank you
A short with high consumption and heat.
Good to have you around Rudi.
regards,
Carlos
Old 6th March 2013, 07:59 PM   #643
Project16 is offline Project16  France
Project16's Avatar
This idea is ingenious tunnel wiljj78!
Regards!
Old 6th March 2013, 08:18 PM   #644
Default The idea is very good....but how you manage to control the wind noise
dear WillJJ78.
Have you reduce the fan speed with step down voltage regulators?
How was the performance pushing the amplifier hard.... what is the temperature you have achieved in the heatsink?
regards,
Carlos
Old 6th March 2013, 08:56 PM   #645
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
WOW! Willy I didn't know you are so hard core, be careful with that don't get hurt dear friend.
Juan
Old 6th March 2013, 09:02 PM   #646
Default Willy is nice.
I do like him a lot, was very difficult to me to dennie to him gerbers...you see he wanted to stretch the board to use his Sankens....i did it with a broken heart to protect the precious design.
Maybe i am over protecting.....maybe.
You see me playing with him here:
http://www.youtube.com/watch?v=8VMxj380J98
regards,
Carlos
Old 6th March 2013, 09:39 PM   #647
Default Almost done
A couple of days more and will go to the manufacturer.
First we gonna check several times...Zimmer will check several times..after his approval i gonna check several times... after my approval Juan will check several times.
The idea here is a single supply to feed two channels pumping out 330 watts RMS at 2 ohms with 5 percent distortion each channel..so...full power or much higher than full power that is 240 watts RMS with a very small distortion (0.008% THD)
Not ready yet...this is just to show you how it gonna look..what gonna be the size....it may have mistakes and we gonna find all them.
Yes we will..for sure we will.
regards,
Carlos
Old 7th March 2013, 05:59 AM   #648
wiljj78's Avatar
Regards!
Thanks Dear Project16.
Wiljj78
Old 7th March 2013, 06:34 AM   #649
wiljj78's Avatar
Originally Posted by destroyer X View Post
dear WillJJ78.
regards,
Carlos
Ohh... Uncle Charlie I 'am unable to operates these toroid's when i have this problem before, I’m in trouble for more than 2 weeks because of this issue, luckily with the help of my NE555 toggle switch I surprise when there is a fault on my AC input this toggle switch cut’s off the AC supply automatically (not sure how does it happen but it helps me a lot when there’s a fault occur on the toroid's and it works like a breaker switch but of course AC input fuse still there to do the right job in case) and these guys are right I didn’t expect these gentleman easily captured this point in my pictures, Thanks to you guys… if you notice in my first build I even make in 3 layers to supply my Class H Amp. before, they on top of each other and if you can see there is insulation plastic sheet on the nuts to protect the contact against the aluminum plate, this is my 1st solution but I’m not happy about it but later I finally found the solution these 3 layers of toroid’s works perfect and normal, very quiet and safe.
Regarding my cooling fan they actually 12-24VDC and fed from my temporary dual speaker protect with regulated fan control, so the fan works in low speed and very quiet when the heat sink temp. Is about 30-45 deg. And the fan speed only increase when the heat sinks temp. Increased
Wiljj78
Old 7th March 2013, 06:52 AM   #650
wiljj78's Avatar
Juan
Thanks dear Juan don't worry, this is just my Extracurricular activity after work, to enjoy the music of my toy’s and to release some stress….. hehehehe..
This 12 meter tower is my baby too and I’m enjoying when I’m up there….
Wiljj78
Dx Blame ST together Dx Super AHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1810 27th July 2016 05:34 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 02:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 01:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 10:26 AM
Copyright ©1999-2017 diyAudio
