Dx Blame ST together Dx Super A
Old 4th January 2013, 10:31 AM   #391
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Please dear friend Juan, inform your heatsink dimensions
in order to uncle charlie check if it gonna be enough or not....it looks not good enough as you gonna use a huge 45 volts supplies.
I see you will use 6 electrolitic condensers, 6800 each one of them and bypassed to ground by small capacitors.
Inform the output impedance you gonna use and if this aluminum block will be used for one or two amplifiers.
I know it is thick, but this just increase the delay time till the aluminum block reaches a temperature above the environment temperature... after that moment, when you start to exchange heat to the air, the area exposed to the air is what gonna decide your heat transference capacity.
It look small...too much small for this amplifier.
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 4th January 2013, 09:04 PM   #392
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Finally!
I guess for me was really easy to adjust the bias “I’m guessing here” first I check all connections all track to make sure I don’t have lose solder around,
I’m right know testing with louder volume, wow it does have a different tone than the supercharger, it has more “life like sound” the timbre timbales drums are a lot more richer
the highs are so nice and noticeable, bass is punchy and nice, also is a lot more louder I feel the sound come out good and clear, I have the volume at 78% in my PC and is really loud
I mean it has power to it, man I’m about to be deft in a minute lol, also no distortion at all.
Set up conditions:
Power Supply +45 0 -45
trim pot to high value possible in my case 191 ohms
I use thermal compound and all main transistors…
side resistors 10R 7 watt…
so I apply power…
I check with my finger the side resistors, warm to the touch, “not hot”…
place the multimeter the voltage was really low 0.098V…
then I begin to adjust to at least get close to 1.5V I start slowly…
after about 25 minutes, I adjust again to 2.48V and wait a little more…
then I decide to leave it like that 2.48V but I still can adjust… “this my case”
I then place the RCA cables, play some music low volume first…
now I’m enjoying I’m happy happy happy !!!!!!!!!
My sincere opinion:
Sound a lot better than Dx Blame ST and MKII Supercharger, important note: it has its own timbre I do notices music come out a lot “alive”
piano good, tromped good, voices good, all instruments sound a lot better in other words. Newton told you I has no power? this baby does have lot of power.
Juan
Old 4th January 2013, 09:53 PM   #393
Default I told ya!.... fully agreed.
Smashed the Dx Blame ST (and the competition)...also beated (easy) the MKIII Hx...and plays loud as a hell.
regards,
Carlos
Old 6th January 2013, 03:02 AM   #394
I thought I post this video but I didn't here is just showing how it look, simple. this a few days old video I will make another one as soon I have both boards completed.
Dx Super A build Cats, guineas, Rosters,birds - YouTube
Juan
Old 6th January 2013, 06:44 AM   #395
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
regards,
Carlos
Time for me to build it,any boards left?
Old 6th January 2013, 06:58 AM   #396
Default For you ... and only because of you, i will give mine ones of special reserve
I have asked Juan to save one more pair to me..... run to catch them.
It is costing 32 USD with delivery..this is what Juan told me.... because he ordered only a few units...this increased the cost as a hell.
I am sending him message saying that you can have my boards.
regards,
Carlos
Old 6th January 2013, 07:03 AM   #397
Thanks Carlos,but then you haven't any boards to build this nice amp?Doesn't Vargas run a groupsbuy for this amp?
Old 6th January 2013, 07:14 AM   #398
Default Depending people interest he may order more boards
But i do not think he will run group buy...he do not like some forum haters that goes bothering...he is a very sensitive guy, had Maya ancestors...half spanish, half native indians.... very sensitive guy...very friendly... a nice guy.
I really think he will not feel good exposed to our forum.
He already shipped two boards to me...i will have mine...i have asked him to save, if possible, two boards for my future use...more two boards to me...these ones, if really saved, will be yours....i have already sent him message saying boards goes to Roovers.
In Brasil, as usual, there's a lot of interest... and soon we gonna have local sells runned by Zimmer...do not know if he will run group buy because i do think he wants 10 percent profit...and this is against rules...he is making something simple..alike the green boards made to Dx Blame ST for Brasil...simple and cheap pcboards.
The amplifier image is not very good Patrick...without the intention to harm, some guys published scope images showing what happens with the amplifier (MKIII Hx) clipping.... so... when nobody uses this range of power...but they had worries about that.... as a result, i do think people became scared..thinking if one Dx model is not perfect... other model can be not perfect too...ahahahahahah!.... we cannot go against people believe..they believe in crazy things and do not believe in people from outside earth.
Was not fast and not that easy to sell these boards.... delayed a lot dear Patrick, usually we sell this ammount in a couple of days....so... the Corporation image is wounded...a pity because this amplifier is the best one from the line.... because scared these folks will lost the change to listen the best amplifier ever made.... by the Corporation..because i have listen the NAD C390DD and it is even better.
I have build three prototypes by myself...there are videos in youtube showing them:
http://www.youtube.com/user/destroyersoueu?feature=mhee
Juan Vargas email adress:
vargasmongo@yahoo.com
vargasmongo@gmail.com
Better to use the gmail....the yahoo adress is new and i am not sure he is going to the inbox.
regards,
Carlos
Old 6th January 2013, 07:33 AM   #399
Default Green boards i told you we have made to Brasil, are these ones
We are making the Dx Supply, to use together Class A and Super A amplifiers.... in the reality you can use with any amplifier... output voltage is stabilized withing 0.25% and voltage is adjustable from 12 to 32 volts... symetrical supply having capacitance multiplier effect (electronic filtering)...it saves capacitors and removes all noise from the mains.
Video available in youtube... test video.... type Carlos Mergulhão or use the link provided in previous posts.
regards,
Carlos
File Type: jpg In Brasil the Blame was a huge success.jpg (142.4 KB, 337 views)
Old 6th January 2013, 12:38 PM   #400
Project16 is offline Project16  France
Project16's Avatar
Hello destroyer X!
I am very interested in this amplifier but I have some questions.
I have Sanken 2SC2922 and 2SA1216, it is OK, ?
Transistors must be "matched"?
I have heatsink 300x120x40 (0.4 K/W) , It is OK?
Finally we can polarize this amplifier in class AB?
Thank you and any the best!
Dx Blame ST together Dx Super AHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 09:53 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 02:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 01:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 10:26 AM
