Dx Blame ST together Dx Super A
Old 4th December 2012, 07:36 AM   #311
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Dx Super A playing at Bazzo's home in São Paulo
This guy repairs automobile steel parts.... we call here "lanterneiro" or "funileiro", i do not know the name of someone that fixes damage in your car doors, for instance.
teste cabeçote 02 - YouTube!
teste cabeçote 01 - YouTube!
They call power unit as "cabeçote"...that means top of an engine, where the valves are.... where the overhead cam shaft is.... the name came from this analogy.
Brazil is too big, we have several "languages" in our country..also music is very different ... this ones sound strange to me.
http://www.youtube.com/watch?feature...&v=DhfqQqeFP4A
Creativity and passion...also a very bad acoustic (ceramic tiles in the floor) and the terrible tone control added to an awfull digital camera resulted more or less.
regards,
Carlos
Old 4th December 2012, 09:19 AM   #312
renatoscp is offline renatoscp  Brazil
Send a message via MSN to renatoscp
Good morning Carlão!
The tone control works correctly, with pots to the center of resistance, the frequencies that come out that are the same ...
I did extensive testing before installing, because if I'm not pleased, I throw the trash ... lol
The real problem is the same of sony digital camera, you can not play what I hear ... And what I hear, is simply indescribable!!
Regards ...
Old 4th December 2012, 10:22 AM   #313
Default Thanks Renato, you are right, these cameras are not good
for audio recording.
Sorry, i hate tone controls...i do like sound directly into the power amplifier input connector...more pure sonics...tone control introduces distortion.
Despite that i have appreciated your videos a lot.
thank you,
regards,
Carlos
Old 4th December 2012, 10:43 AM   #314
Yes, blame the tone controls become completely unnecessary, since the signal source is clean, which is not often ... So, I implemented this to compensate for bad signal sources, with some deficiency in attendance ...
I tested the controls, the LM 1036 proved very effective, without distorting the perceptual level, unlike other tone controls that do not use CI, but resources for separating frequencies through resistors and capacitors ... I do not like these ...
Hug!
Old 4th December 2012, 11:45 AM   #315
Rena,
I don't know what opamp you are using as the unity gain buffer, but do check the datasheet for information on the link from Out to -IN. Some opamps prefer to see a low value resistor in this link, to help prevent misbehaviour.
Check that you have HF decoupling in the correct locations.
regards Andrew T.
Old 4th December 2012, 11:51 AM   #316
DX is suggesting that some Members/Builders may want to use the fuse alternative resistor to check for amplifier current when using Ibias approaching 1A. Don't do this.
If the PSU is putting out say +-40Vdc when the amplifier is not connected and this drops to +-39.5Vdc when the amplifier is connected then the setting of the bias will further reduce the supply at the amplifier power input terminals slightly, maybe down to +-38Vdc when the bias is set to 100mA to 200mA.
If you insert a 10r resistor instead of the fuse, then the output bias will change from the set value. It might drop to 10mA, but much worse the supply voltage after the resistor will drop badly.
200mA through a 10r resistor will drop 2V.The amplifier will have +-38Vdc at the power terminals but it will only have +-36Vdc after the resistors.
This gets MUCH WORSE if you set the bias to 500mA, Vcc/Vee becomes +-33Vdc,
@ 700mA: +-31Vdc, @ 1A: +-28Vdc
DO NOT SET output bias with resistors replacing the fuses.
The amplifier must see the full supply voltage when you set the output bias.
Use the Vre method to check the output bias current.
regards Andrew T.
Old 4th December 2012, 04:58 PM   #317
Default We are still discussing about resistors
Me, Zimmer and Juan.
It is funny.
regards,
Carlos
Old 4th December 2012, 07:34 PM   #318
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Talking Dx Super A BIAS
Here is a quick instructional information of how to adjust the bias on the Dx Super A.
Juan
File Type: png Dx Super A adjustments by Carlos Mergulhão 1.png (232.1 KB, 409 views)
File Type: png Dx Super A adjustments by Carlos Mergulhão 2.png (721.8 KB, 399 views)
File Type: pdf Dx Super A adjustments by Carlos Mergulhão.pdf (180.3 KB, 208 views)
Old 4th December 2012, 07:48 PM   #319
Default Great Vargas...we are turning into a great team
Long life to the Corporation, the Union of the best world audiophiles..the real DIY folks.
regards,
Carlos
Old 5th December 2012, 03:02 AM   #320
Here are the files for etching hot iron and UV light sensitive boards, there are confusion of if the files is mirrored or no I'm giving you both normal and mirrored files PDF format. chose the one you need not all printer work the same way.
Juan
Dx Blame ST together Dx Super AHide this!Advertise here!
Dx Blame ST - Builder's thread - post pictures, reviews and comments here please. destroyer X Solid State 1874 28th August 2017 10:53 PM
Overheating on NEW DX Blame super DIYGEEK Solid State 22 28th March 2012 03:30 AM
Where is the original DX Blame ST thread? johngalt47 Solid State 5 17th March 2012 02:03 PM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Dx Blame ST, operating from 18 to 24 Volts (unloaded) - Class A destroyer X Solid State 51 15th June 2010 11:26 AM
